    [Info] Allowable Classes for "set_attribute"
    57 Posts 12 Posters 8.0k Views 12 Watching
    • K Offline
      kwalkerman
      Under the Ruby API for "set_attribute" we get:
      Arguments:
      dict_name: The name of an attribute dictionary.
      key: An attribute key.
      value: The value for the attribute.
      Returns:
      value: the newly set value if successful
      but, it doesn't tell you what type of values are allowable. Here is my short list:
      allowed:
      String
      Fixnum
      Float
      Array -- For arrays, every element in the array needs to be one of the allowed types on this list.
      TrueClass
      FalseClass
      Length
      Geom::Point3d (tested under SU8 M1)
      Geom::Vector3d (tested under SU8 M1)
      not allowed:
      Entity
      Hash -- this can be stored following Dan's guidelines below.
      Be careful with hash, because if you have an array, and one of the array values is a hash, it will return the array, but instead of returning the hash, it will return nil.
      Additions? Corrections? Comments?
      Karen
        Yea - wish the API docs would spesify this.
        CAn't remember if the TrueClass and FalseClass worked..
        • Dan RathbunD Offline
          Dan Rathbun
          @kwalkerman said:
          not allowed:
          Hash -- (kind of strange, as array is allowed)
          A JSON string is a hash definition, almost verbatim Ruby, with quotes.
          The diference is that the => are replaced with colon. JSON (JavaScript Object Notation,) strings are handy because you can pass them to webdialogs. They can contain nested Arrays, and I think even nested JSONs.
          But if your data is going to stay within Ruby, and you want "record type" data fields with keynames and values, then use a hash.
          It's VERY easy to store a hash in an attribute.
          (Get ready to smack your forehead.)
          my_hash = {'Name'=>'Dan','Age'=>49,'Stature'=>5.5,
                     'FavFoods'=>['Mac and Cheese','SpiceCake','Coffee']}
          some_entity.set_attribute( "dict_name", "hash_att", my_hash.inspect )
          I'm not here much anymore.
            Jim
            When you say Arrays are allowed, what about the types of the elements?
              @dan rathbun said:
              How do you turn it back into an hash when you read it?
                Jim
                Unless your Hash string includes quotes, in which case you need to escape those first.
                  Dan Rathbun
                  NOPE.. Ruby does it for you.
                  ` hashStr = %( {"Stature"=>5.5, "Name"=>"Dan", "FavFoods"=>["Mac and Cheese", "SpiceCake", "Coffee"], "Age"=>49})
                  hashStr.inspect
                  " {"Stature"=>5.5, "Name"=>"Dan", "FavFoods"=>["Mac and Cheese", "SpiceCake", "Coffee"], "Age"=>49}"
                  my_hash = eval(hashStr)
                  my_hash.class
                  Hash`
                    Jim
                    Huh, I thought I had problems with that in the past.
                      Dan Rathbun
                      Could be.
                      • Might have been using Ruby 1.8.0* Might have been conflicts between PC (1.8.0) and Mac (1.8.5)* I imagine you could confuse Ruby with poor use of delimiters, or maybe embedded newlines?
                        I would always recommend using .inspect to build the string, as it:
                      • Correctly knows how to iterate the hash, and any nested structures inside it, like nested arrays, nested hashes, etc.* For objects that it does not know how to 'convert' it will make an 'info string': "#Sketchup::Face:0x3F56D20A" (or similar)* Uses the same delimiters (double quotes,) for all strings and hash keys (which allows the use of a single quote for possesion apostrophe. ie: "Dan's idea!"
                        Dan Rathbun
                        See the post directly above.
                        The "tip" on using .inspect (to build the attribute strings,) for hashes, goes also for arrays.
                        The .inspect method will convert hashes nested inside arrays, and arrays nested inside hashes, etc. Multiple levels deep as well.
                        • K Offline
                          kwalkerman
                          Dan,
                          Very nice. I will definitely use this. Too bad it's not embedded in SU though.
                          Jim - I have found that any sub-components of arrays also need to be one of the allowable classes.
                          Thom - trueclass and falseclass also work. I'm updating the first post accordingly.
                          Karen
                          • Z Offline
                            zitoun
                            VERY useful thread, thanks !
                            Please make it kind of sticky: I've been chasing an uncatchable bug for hours, ignoring this information... Others might like to know this in the future!
                            The light at the end of the tunnel is a train.
                              Dan Rathbun
                              To recover a hash-string from an attribute, you eval() it into a reference.
                              hashStr = some_entity.get_attribute( "dict_name", "hash_att" )
                                Length classes also seem to be stored and recovered properly. I'd thought that maybe it got read back as Float, but in my tests I seem to get Length - anyone confirm?
                                  @kwalkerman said:
                                  Array -- good to store by doing "array.inspect" first, see Dan's comments below
                                  Only if the array contains hashes. If the array only use the other allowable types there is no need. Might be less overhead since it's not parsing between strings.
                                    Geom::Point3d also seems to be possible to store:
                                    ` pt1=Geom::Point3d.new(1,2,3)
                                    Point3d(1, 2, 3)
                                    pt2=Geom::Point3d.new(4,5,6)
                                    Point3d(4, 5, 6)
                                    pt3=Geom::Point3d.new(7,8,9)
                                    Point3d(7, 8, 9)
                                    pt_array = [ pt1, pt2, pt3 ]
                                    [Point3d(1, 2, 3), Point3d(4, 5, 6), Point3d(7, 8, 9)]
                                    model.set_attribute('test', 'bar', pt_array )
                                    model.get_attribute('test', 'bar' )
                                    [Point3d(1, 2, 3), Point3d(4, 5, 6), Point3d(7, 8, 9)]`
                                    I even saved the model and reopened it just to make sure it worked across sessions.
                                      Although storing/reading-back a 'point3d' or a 'vector3d' as an array [.to_a] would be 'safer' ?
                                      Presumably a 'transformation' is not storeable unless it's first made into an array ?
                                        I was storing points as arrays - because I just assumed point3d's would not work. But they appear to do so. In which case I'd prefer to do so unless there is any known issues.
                                        • K Offline
                                          kwalkerman
                                          Nice. I just tested it as well. I'll add it to the list.
                                          It also seems to work as an attribute dictionary key:
                                          p1 = Geom::Point3d.new(1,2,3)
                                          p2 = Geom::Point3d.new(4,5,6)
                                          entity.set_attribute "k", p1, p2
                                          Karen
                                            hmm... interesting.
                                            I a haven't tried, but I'd think that Vector3d should work as well. (Though one can never be sure until it's tested...)
                                            • 1 / 3
