    Obtaining component transformation
    6 Posts 2 Posters 568 Views 2 Watching
    • G Offline
      Gouranga
      Hi, I have been looking for a way to read components' transformation information. I need to create a very simple scene from boxes and then recreate it in my C++ program with hardcoded values (as Physx collision objects). I need translation, scale and rotation in any possible format, although three angles are preferable. I don't have time to learn ruby and sketchup's API. I thought I could just read the numbers somewhere, but unfortunately sketchup doesn't seem to find them useful enough to reveal them.
      Thanks in advance for advice.
        You're going to struggle if you don't take some time to look at the API. You need to know what you are dealing with.
        Getting the transformation for either a group or component is easy:
        http://code.google.com/apis/sketchup/docs/ourdoc/componentinstance.html#transformation
        Then, with the Transformation object, if you just want the matrix, use the .to_a method:
        http://code.google.com/apis/sketchup/docs/ourdoc/transformation.html#to_a
          hmm... did you mean you wanted to read it directly from your C++ app?
          Or using a C Extension?
          • G Offline
            Gouranga
            Actually I would be fine with just manually writing the numbers to my code, but I can't find them anywhere. I meant I didn't have time to learn ruby so that I can't write my own addon that would print out the transformation info for example to a text file.
              Ah - so you don't need like feedback?
              So you just need something that outputs the transformation matrix of the selected components to a text file?
              • G Offline
                Gouranga
                Exactly.
