    [Resolved] How select a face created in another face?
    7 Posts 5 Posters 629 Views 5 Watching
      LSeibt
      Hello everyone
      I am developing a plugin to make holes in a given geometry.
      Select the face where I will apply this geometry and design lines that will make this hole.
      How do via code, to capture that face created as a result of this new geometry that was drawn on the selected face?
      • Dan RathbunD Offline
        Dan Rathbun
        ` set1 = Sketchup.active_model.entities.to_a
        create new geometry
        set2 = Sketchup.active_model.entities.to_a
        subtract set1 from set2
        setnew = set2 - set1
        facenew=false
        setnew.each {|e| facenew=e if e.class==(Sketchup::Face) }`
        That is a very simple example, it may be more complex if the face your 'carving' is within a Group or ComponentInstance.
        I'm not here much anymore.
          @dan rathbun said:
          facenew=false setnew.each {|e| facenew=e if e.class==(Sketchup::Face) }
          what about:
          facenew = setnew.select{|e| e.is_a?(Sketchup::Face)}
            Dan Rathbun
            @thomthom said:
            what about:
            Yes, but facenew WILL be an array, with possible more than 1 face.
            The original poster would need to check .areaof each item in array, to determine which face was smaller and delete it.
            • TIGT Online
              You know the 'face' that will contain the new face - since you said you selected it.
              Since you are creating new geometry you will know the 'edges' you have just added to the entities.
              If you make a circle it returns the edges as an array. If the hole is some other shape you will be adding these so you can get references to them?
              Any one of these new edges (e.g. edges[0]) should have two faces - the one that is NOT 'face' is the 'new face' ?
              If there's a chance the new face won't be wholly on 'face' then if an inspected 'edge' doesn't include 'face' in its 'faces' then try processing more like this...
              ### assume the selected face is called 'face'
              ### and new edges you've added are in an array called 'edges'
              newface=nil
              0.upto(edges.length-1).each{|i|
                if edges[i].faces.include?(face)
                  if edges[i].faces[1]
                    edges[i].faces.each{|f|
                      if f != face
                        newface = f
                        break
                else
                  next
              ### 'newface' is the new face or 'nil' if it's not on 'face' at all
              ### you can then find the new 'separate' face if desired...
              newface = edges[0].faces[0] if not newface
              ### 'newface' is found at last even if not on 'face' at all !
              ### alternatively 'not newface' tells you it's missed face all together...
                todd burch
                If you are using entities.add_face, the new face created is returned as the result. You can create the face with either lines (edges) or points. No big deal.
                  LSeibt
                  Yes .. You're right.
                  This morning I could get tested and worked properly in this way.
