    Arroway wood texture question
    14 Posts 4 Posters 3.3k Views 4 Watching
    • soloS
      solo
      Does anyone have the following Arroway bundles:
      Wood veneer, wood vol 1 or wood vol 2? (not wood flooring vol 1)
      The reason I ask is due to the trial size limitations I cannot verify if the textures I need is seamless over a 5x5ft panel.
      So if you have one of the bundles let me know and I will ask if you can check the texture for me.
      http://www.solos-art.com
        Pete, I don't have either of those volumes although they sound interesting. The website indicates that there are images that cover approximately 3m x 4m. That should be plenty for your 5' square panels.
        I do wonder how they handle the width. It's difficult to find single sheets of veneer that are 9 feet wide. A panel would typically be veneered these days with rotary cut veneer although you can also get slip-matched and book-matched veneers, too.
        • B
          bocomofo
          I dont have the bundles but I did notice that the on the arroway website, when looking for the samples, it does say that the material is seamless vertically.
          I would infer from that they are not seamless horizontally.
          Maybe not the answer you are looking for, but hopefully of some help!
          j
          • soloS
            solo
            That's what worries me, too expensive to buy without knowing, wish there was a way to buy single textures.
              Does the material have to be seamless horizontally (across the grain)? Real wood wouldn't be seamless. I'm just asking.
              • soloS
                solo
                I agree, but this is a veneer. πŸ˜‰
                  But is it supposed to be a real wood veneer or plasti-wood?
                  • marvins_dadM
                    marvins_dad
                    Which specific texture are you looking for?
                    Looks like I have Volume 1
                    My Gallery
                    • marvins_dadM
                      marvins_dad
                      Example: Wood-01 6002px x 6002 px or 83.351"x83.351" at 72dpi = about a 45mb png file
                      My Gallery
                      • soloS
                        solo
                        Antoine, if you can model a plane in SU 60 x60" and slap on wood 21 (great maple) and see how it goes, if there is any repeat to the pattern, tiling, I'd appreciate it.
                        http://www.arroway-textures.com/en/products/wood-1/contents
                        • marvins_dadM
                          marvins_dad
                          I created the texture and gave it the 83+" scale. That makes it about a 6'+ texture...so it won't repeat on a 5'
                          If you like I can share jpg versions with you...they are still quite large though ~19mb...that way you can test it out yourself before you purchase. I can set up an FTP for you to pull it down.
                          My Gallery
                          • soloS
                            solo
                            Thanks for the test, looks about right, I will chat with my financial advisor (wife) about getting the bundle.
                            No need to go through the trouble of uploading, it's probably not allowed in any case, thanks for the offer however.
                            • marvins_dadM
                              marvins_dad
                              I can assure you they are pretty heavy files. I sometimes go to them for the range, but they can bog down really fast because of their size. I have even cropped a few down in the past.
                              My Gallery
                              • soloS
                                solo
                                I got their wood flooring bundle a year or so ago and agree they are huge, especially for SU, I normally use the bump map from the sequence in SU in order to get the texture mapped right, then in render studio I replace it with the diffuse and slot in all sequenced maps accordingly.
                                They are hands down the best textures I have ever used.
