    Export For CAM software
    extensions
    51 Posts 14 Posters 20.5k Views 14 Watching
      sketchdata
      I will work up a report that groups/totals like parts based on their dynamic attributes, and then the report can be exported to Excel. Since SketchUp stores the measurements in Inches, we had to add a conversion to the Model Units (mm, fraction, decimal) when displaying the data on the reports. I'm still thinking about the Language conversion issue, we need to convert the column headers and the attribute names to your local language? Do the attribute values need to be converted too? What language would you like it converted to if I can produce a sample spreadsheet?
        dedmin
        These are sample files. A SketchUP's component with name and attributes in Bulgarian language and Excell table from this attributes.
        I don't know,but seems that SketchUP recognizes different languages in attributes and correctly displays them.
        Panel.skp
        Cutlist.xls
          sketchdata
          When I open up the "Component Options" dialog in my SketchUp I still see the Bulgarian, but when I open the "Component Attributes" I see English LenX,LenY,LenZ. So I created a report to group and sum qty on components that have the exact same attribute values and then used the "Display Label" as the column header, which is not the internal attribute name, but the name that displays on the "Component Options" dialog. I attached a sample SKP which has copies of your part with different sizes so I could test the report quantity column, also attached is a PDF and Excel file of the report. Please let me know if this helps, or if I'm way off. Thanks...
          Panel_Test.skp
          Panel_Test.pdf
          Panel_Test.xls
            dedmin
            Yes, that is! SketchUP doesn't allow non English characters for attributes, but no problems with attributes labels - and that visible information is really valuable for the report - what You see is what You want on the report! Not how it is with the generate report - a bunch of useless information! This way You really control what info and how to export! Thanks!
              Bertier
              interesting subject.
              keep me posted, what about French accents ? !
              keep up the good work
                Numerous progs have some trouble with accents! 😮
                In the path's folders, files'names or even in the prog it self!
                For example Zbrush can't have a French Interface due the French accents! 😢
                Because it was not managed from the beginning, now it's to late! 😮
                So don't take names files or path folder with accent when you write in French 😉
                • P Offline
                  paulhankin
                  @dedmin said:
                  Fully agree with You!! I wonder why nobody did this already - there are so many fellow woodworkers ready to pay for this!! But when You export a 5mm circle from SketchUP as .dxf it is not a circle anymore - that is why I asked above if this is a problem with CAM?
                  What it could is when exported convert all circles to a high segment polygon,via a input box
                  Ie a circle that has 10 edges could be converted to a circle with 100 edges giving the appearance of a more precise circle
                  depending on the tolerance of a hole. and insert a cross hair in the centre to denote the centre of the circle of a standardised size say 5x5mm or an input box could include this feature to choose.
                  This then could have an option to convert all holes in model , voila problem sorted
                  obviously this would only work on flattened geometry for export to 2d cad cutting , say laser cutting
                  What do you think?
                  Paul
                    dedmin
                    Sorry, but I don't have experience with CAM and CNC. Maybe somebody else can answer - I'm also interested in this. Waiting for a long time somebody to take SketchUP more seriously in this area and develop the needed tools and plugins.
                      Catalyst
                      Exporting faces using the native Sketchup pro dxf export will create true dxf arcs and circles.
                      When I export bezier curves or splines Sketchup creates segmented dxf shapes. This is not a problem as increasing the number of segments will create the illusion of a smooth curve.
                      Regards,
                      Yvan
                      • K Offline
                        kyyu
                        What do you think?
                        Paul
                        You can always increase the circle segment size to get better circles. But gcode also does circular interprolation (G02 and G03). One is for clockwise and the other couter clockwise. You just need to supply the end points of the segment and the radius or center. The phlatscript sketchup plugin makes some use of this. For example a 3 segment circle and the simulated gcode, pictured below. I don't know if my eye is playing tricks or not, but it looks just a fraction off. Possibly round off error. But this is an extreme case. With a few more segments it looks perfect. Certainly, a 8 segment circle looks perfect.
                        3 segment circle and simulated gcode
                          cruffe123
                          @yvan said:
                          The geometries should also be exported as follow:
                          1. Create a dynamic component with attributes to be exported in the csv file.
                          http://www.catalystinteriors.com.au/images/stories/sketchup/01.png
                          1. Select primary face in all components to be machined. (components such as hardware are excluded if no face is selected). Only one face per component can be selected.
                          http://www.catalystinteriors.com.au/images/stories/sketchup/02.png
                          1. Tooling is set by placing geometries in specific layers. For example vertical drilling with a 5mm bit would be associated with the dxf layer called “DV_5”; Routing offset for external shape with DXF layer “ROX_9” (9 for a 9mm router bit.) any combination of machining can be accomplished by linking tooling “strategies” in the CAM software with DXF layers created by Sketchup.
                          http://www.catalystinteriors.com.au/images/stories/sketchup/03.png
                          1. When the model is ready all “primary” faces are exported as DXF polylines in a specified folder together with the csv file.
                          http://www.catalystinteriors.com.au/images/stories/sketchup/04.png
                          1. The csv file is then used to automate the import in the CAM software (Enroute, Aspan etc...)
                          http://www.catalystinteriors.com.au/images/stories/sketchup/05.png
                          this is very interesting and this process is exactly what i have been looking for?
                          i need to be able to select a face of a cabinet, automatically apply the shelf drilling & hinge boring.
                          export this as a flat dxf, i have been doing this with a section slice and opening this is in autocad to set
                          requirements for cam but the dxf from sketchup comes through with broken segmented lines so i use
                          the dxf to trace. can anyone help with this??
                          • 3 / 3
