    Why my model looks like this?
    3 Posts 1 Posters 342 Views 1 Watching
      Subhs
      Hi..
      I'm new to Sketchup, so, please bear my (maybe) stupid question... πŸ˜„
      I was working with creating my home on Sketchup. Suddently it got jeopardized and looked horrible.
      Spoiled C99
      But when I render the same (jeopardized) model with IDX, it shows correct.
      Spoiled C99
      Could you pls help me?
      TIA
      C99 Rendered
        Subhs
        Well, I got the answer (from SketchUcation only!)
        It's primarily with the Intel display card issue.
        Goto Windows > Preferences > OpenGL > Switch between the options. Click OK.
        If it shows ok with the either option, check back the previous option. If it's ok, it's fine. Else, select the option works best for you.
        Hope this helps!
          Subhs
          Sorry to post again...
          If it happens after adding shadow or a texture, then, it's definitely display card issue, because, it cannot take so much of loads. Switch off shadowing and do the same as mentioned above, it should be ok.
          Thanks.
