    Painting a quadrangular
    10 Posts 3 Posters 799 Views 3 Watching
    • K
      kolem
      I took the linetool.rb and tweaked it a little to fit my needs, and that was making a line and then hide it, the use for it if you have a quadrangular that sketchup cant 'paint' you make that line which makes 2 triangles that sketchup can 'paint'.
      the thing is that when i draw that missing line it doesn't paint the 2 triangles?
      any ideas?
      • thomthomT
        SketchUp can't paint a quadrangular?
        Can you provide an example?
        • thomthomT
          Oh wait - when you say 'paint' - do you mean it doesn't create the faces?
          So you in some cases have a quadrangular that isn't co-planar - so you need an edge going across it?
          With your tool - that creates the edge, call Edge.find_faces on the edge you create. That will make it behave like SU's native line tool and generate faces formed by the face if possible.
          • K
            kolem
            if its not on the same plane
            • K
              kolem
              yea that case,
              how do i use Edge.find_faces
              • K
                kolem
                i looked at the example, and did this:
                	myline=view.model.entities.add_line(p1,p2)
                	myline.hidden=true
                	face = entities.add_face(p1,p2)
                not working, probably a syntax error.
                any ideas?
                • thomthomT
                  You are trying to create a face with only two points.
                  The .find_edges leaves SU to create the faces. As you can see from the API docs - that method is called on edges. So you call that method on the reference to your edge.
                  Like so:
                  myline=view.model.entities.add_line(p1,p2) myline.hidden=true myline.find_faces
                  • K
                    kolem
                    ok it works but I don't get the problem
                    whats the difference between find face and add face?
                    • TIGT
                      The method entities.add_face(..............) adds a face from three or more coplanar points/edges/etc that you specify - and only adds that face.
                      But edge.find_faces finds all of the faces that edge could have - these might be additional 'internal faces' in complex 3D form - as there could be several sets of coplanar edges that will 'take a face' - some of which you probably don't want!
                      • K
                        kolem
                        thanks a lot!
