    SU Components Window freezes (from new) MacOSX
    3 Posts 2 Posters 305 Views 2 Watching
    • X Offline
      xgraphica
      Yesterday I opened up SketchUp to work on a small model and only some of the windows/palettes opened up. One that didn't was the components window. This one refused to open when selected from the "windows" menu option. When it did open, after a second attempt, it was unresponsive. If I "right-clicked" on Sang in the components window, I could delete him. The window then appeared to work, but as soon as I tried to access the Google warehouse it froze again.
      I have now completely uninstalled SU many times and re-installed SU 7.1 Pro, 7 Pro and 7.1 Free (all as basic, no frills installations). The problem persists. I've checked the app permissions and the components folder permissions (Library/Application Support/GoogleSketchup etc.. and repaired permissions on my main HD.
      This occurs with no models loaded, straight from the default screen. I think it is something to do with the components window trying to make a connection to the components library/folder or external (Google Warehouse?) but can't figure out how to "reset" it - I was hoping a clean install would solve the problem.
      Everything else in SU is working as expected except the components window - which does make life a bit more difficult than strictly necessary! Nothing else has changed with my computer (no new software installs or upgrades etc). Firewall settings haven't changed, all other internet/mail connections are working normally.
      System: MacPro 8 core, OSX 10.5.8 10Gb RAM, NVIDIA 8800GT
      If anyone could give me a clue as to what to try next?
      Cheers
      XG
      • daleD Offline
        dale
        Have you recently installed any new plugins?
        If your rendering, what application(s) do you use?
        • X Offline
          xgraphica
          I did add one new plug-in/ruby (tt_uv_toolkit.rb) but that has long since been deleted - I'm just trying to get it working with a clean installation and new window!
          All signs of the "old" stuff have been moved to another drive, the main hard drive has had all traces (that I can find) of SU and associated files removed.
          I render files with Podium (which continues to work as expected)
          Thanks for your reply.
