    Right Click->Hide
    16 Posts 3 Posters 1.2k Views 3 Watching
    • K Offline
      kolem
      is there any way I can make a tool that you draw a line and it hides it automatically, instead of drawing and then right click it and "hide"?
        Yes. The Tool class allows you to create your own custom tools: http://code.google.com/apis/sketchup/docs/ourdoc/tool.html
        • K Offline
          kolem
          Any existing code i can look to learn from, i have basic programming knowledge but I'm not familiar with the Ruby syntax.
            There is an example code snippet that comes with SU. But it's not very good - the code is confusing.
            I'd look at some other plugins with tools.
            I do imagine I saw another thread not too long ago in the same topic - don't have the link at hand. Will see if I can dig it up.
            • K Offline
              kolem
              I read the tutorials on code.google.com, but it doesn't help a lot.
              I tried to look at the linetool.rb and I just got confused...
                Yea - that's the one I talked about. Not very good.
                  Maybe Jim's construction line tool is of help: http://sketchuptips.blogspot.com/2008/02/plugin-construction-line-tool.html
                  Have a look.
                  As for SketchUp plguin writing in general:
                  You will find many useful links in this thread: http://forums.sketchucation.com/viewtopic.php?f=180&t=10142
                  It's worth noting that all plugins share the same environment, so it's important to learn how namespaces (modules and classes) works in Ruby - and use them. Otherwise you might end up with conflicts with other plugins.
                  And a big no-no is overriding basic Ruby and SketchUp methods. Then you will most likely break other people's scripts.
                    Try this... take the 'linetool.rb' code and copy it - make a new tool class named 'HiddenLineTool' say...
                    and used that wherever 'LineTool' used to appear in the text, and also make a new def linetool >> def hiddenlinetool etc...
                    Find the line of code that creates the geometry - it reads view.model.entities.add_line(p1,p2)
                    and adjust it so it reads myline=view.model.entities.add_line(p1,p2)
                    and insert a new line of code immediately beneath that that reads myline.hidden=true
                    Now when you draw the line it'll automatically become a 'hidden' line - I suggest that you have 'Hidden Geometry' switched 'on' whilst using this tool, otherwise you could get very confused...
                    Note also that you could make another version of it [GuideLineTool ?] to draw a guide-line (cline) by changing that one line to view.model.entities.add_cline(p1,p2) instead
                    • K Offline
                      kolem
                      ill try that, another issue is that i have a problem editing the code in the notepad, i get all the code in one long row, any suggestions?
                        Get a better editor than Notepad. Get one that provides syntax highlighting - makes reading the code much easier.
                        I use Notepad++ http://notepad-plus-plus.org/ - free app with a support for a wide range of languages.
                        • K Offline
                          kolem
                          thanks a lot!
                          well, I started off by looking at the code and I'm starting to get an idea of how things work.
                          i edited the linetool file and changed the class to 'hiddenlinetool', etc...
                          and added the line TIG wrote, however, I get an error:
                          class/module name must be CONSTANT
                          with a referring to this line:
                          class hiddenlinetool
                          ideas?
                            Yes - constants in Ruby must start with capital letters.
                              The class would be HiddenLineTool
                              but the shortcut def hiddenlinetool...
                              • K Offline
                                kolem
                                Ok, seems like it is going to work, now, how do i execute the tool?
                                window>preferences?
                                  To test type hiddenlinetool into the Ruby Console.
                                  Later on when it's debugged to make a 'Plugins' Menu item use this code at the end - outside of the class etc
                                  if not file_loaded?(File.basename(__FILE__))
                                    ### make command
                                    cmd=UI;;Command.new("Draw Hidden Line"){hiddenlinetool}
                                    cmd.status_bar_text="Draws a line and immediately hides it..."
                                    ### menu
                                    UI.menu("Plugins").add_item(cmd)
                                    file_loaded(File.basename(__FILE__))
                                  end#if
                                  To put the tool into the 'Draw' menu instead, you just change 'Plugins' to 'Draw'.....
                                  • K Offline
                                    kolem
                                    never mind i got it working, thanks for the help
