    Making Curve Coplanar
    3 Posts 3 Posters 471 Views 3 Watching
      Jim57
      I'm reworking a model, and I copied a curve from a group in order to remake it. Turns out the curve is not coplanar, it's off by a little bit. Is there a simple way to make it planar? This is one edge of a vertical panel.
      Thanks,
      Jim
        You could use the drape tool to drape it onto a flat face then use the draped curve. You would need to rotate it first however as the drape tool works along the Z axis.
        • BoxB Offline
          Thomthom's Vertex tools will do it for you too.
          http://forums.sketchucation.com/viewtopic.php?t=29636
