Making Curve Coplanar
I'm reworking a model, and I copied a curve from a group in order to remake it. Turns out the curve is not coplanar, it's off by a little bit. Is there a simple way to make it planar? This is one edge of a vertical panel.
Thanks,
Jim
You could use the drape tool to drape it onto a flat face then use the draped curve. You would need to rotate it first however as the drape tool works along the Z axis.
Thomthom's Vertex tools will do it for you too.
