    Importing Google EarthTerrain
    6 Posts 4 Posters 615 Views 4 Watching
      mast3rpyr0
      Hey guys. I am attempting to design a city on an island in the middle of the ocean that I found in Google Earth and I would like to build it directly on the terrain model. However, the island is quite large and when I click the Get Current View button in sketchup it says that I am too high. Is there anyway for me to use the entire island model?
      Thanks for the help!
        bocomofo
        Try zooming in to the google earth model a bit so that Skethcup will allow you to import a section of the island.
        Then in Google Earth pan over to a new area, try to make it over lap the previous section slightly and back in sketchup import this new area.
        Build it up like a patchwork quilt. Google Earth and Sketchup should place it in the right position...
          mast3rpyr0
          Ok thanks, I got a decent model of the island now. Would there happen to be any tool to cut off where one model sticks out higher than the same area on another section?
            Mamer
            I have a question along the same lines, rather than opening a new thread I figure I'll just jump into this discussion.
            After importing a terrain layer from Google Earth into SketchUp, how then do you draw ON the Terrain. For example. Say I want to build a series of buildings on a hillside, but I would prefer to connect the walls directly to the terrain, rather than connecting them below it. Is there any easy way to accomplish this?
              d12dozr
              Could you attach a picture to illustrate your problem please?
              There are a few ways to do this, I would draw the building separately temporarily making the 'basement' deeper than necessary, group it, then move it into position and Right click -> "Intersect with model".
              Another way is to model the building and use the sandbox Stamp tool to stamp the building footprint into the terrain.
              http://goo.gl/f7ooYh
                Mamer
                Another way is to model the building and use the sandbox Stamp tool to stamp the building footprint into the terrain.[/quote]
                Thanks! I'll give it a shot.
