    Importing SVG
    14 Posts 8 Posters 11.9k Views 8 Watching
      cloo
      I can`t get svg.rb working.
      The plugin requires REXML ruby library (what is not clearly stated), and even having that in SU7.1 produces a cryptic error:
      http://gyazo.com/cb6b9a12e80a1f55bb998ab108614ccc.png
      Do you have an idea what`s the problem, and can anybody import SVG to sketchup at all?
        @cloo said:
        If you read the file early on it requires a file
        require 'rexml/parsers/pullparser.rb'
        this is where it's failing
        Inside the Plugins folder you need a folder called rexml, inside that a folder called parsers and inside that a file called pullparser.rb - I suspect that that file will also have require/load set for other files in the folder so you need to check that too...
        This IS explained in the linked web-site as:
        This script allows to use Inkscape to create 2D images and to create Sketchup group(s) from the SVG File Inkscape has written.
        The script requires rexml: You will find the files in a standard ruby environment: Copy the rexml Folder to your Sketchup Plugins Folder.
        You will also need the forwardable.rb and set.rb from ruby in your Plugins Folder.
        You might think that the rexml is here http://www.germane-software.com/software/rexml/ [Development.zip and API_Docs.zip downloads] - and you'd will need to rename its copied folder as just rexml inside ../Plugins/ BUT it doesn't contain ' pullparser.rb' SO DON'T BOTHER !!! You actually need a full version of Ruby instead http://www.ruby-lang.org/en/ and copy the rexml folder from that !!! Aaargh! This is perhaps the least painful route http://rubyinstaller.org/downloads/ Capture.PNG Copy this folder into ../Plugins/
        and the other two .rb files here http://www.koders.com/ruby/fidFC6B854727851FAB8FC100CF0B7AB5BAE3F3F7B3.aspx?s=open3 [click Download link on left] and here http://www.koders.com/ruby/fidD93919848069320713B57FAB7E319C679FD5CA55.aspx?s=open3 [click Download link on left] - these go into ../Plugins/
        It could have been made a whole lot easier ! πŸ˜’
        πŸ€“
        PS: It also needs bezier.rb which you can get from here... http://sketchup.google.com/download/rubyscripts.html πŸ˜•
          cloo
          Thank you TIG! Life is much easier with folks like you. πŸ‘ .
          I`ll try to give something in my turn, too.
          Here is the plugin with all the needed scripts: svg.rb and all the scripts that it requires: rexml library, bezier.rb, forwardable.rb and set.rb
            Jim
            Just so you know, we've had this posted back in 2008 (but now removed)
            http://forums.sketchucation.com/viewtopic.php?f=180&t=13475
            The problem is the file set.rb uses a Set class that is in conflict with SketchUp's built-in Set class, which can cause other plugins which rely on the Set class to fail (in sometimes subtle ways that are hard to debug.)
            It may be possible to fairly easily wrap the entire plugin in a unique namespace, but I don't think anyone has tried it.
              cloo
              Yes, I found that.
              But I think that declaring this incompatibility is much better than removing a possibility - so you don`t ban people from using a function when necessary.
              • shuraS Offline
                shura
                Does that mean it is very likely to risk conflicts when installing svg.rb?
                I'd love to have vectors from Inkscape imported, but I don't want to mess up my plugins...
                πŸ˜•
                  cloo
                  Svg.rb is ok, but it loads set.rb.
                  Set.rb disables smoove from sandbox tools.
                  That`s it.
                  So I keep both svg.rb and set.rb away from plugins folder and move them back in only when needed.
                    You could try this:
                    'disable' set.rb by renaming it set.rb.txt
                    edit the file ../Plugins/remxl/parsers/baseparser.rb
                    near the start disable the require for set by prefixing the line with a #, thus
                    **#**require 'set'
                    You should still get the required 'Set' functions loaded by Sketchup for the svg tool AND sandbox...
                    Try it this way and report back - you should then get both tools working..........
                    • I Offline
                      ideas_arte
                      @tig said:
                      You could try this:
                      **#**require 'set'
                      Before you follow the instructions:
                      before
                      After TIG instructions:
                      After
                      I have no knowledge of scripts, just follow the instructions.
                      Regards to all, and I hope someone helps us.
                      • shuraS Offline
                        shura
                        oh, oh, I'm a bit frightened πŸ˜‰ But however, thanks for your efforts guys! Guess I'll be not diving into svg too soon, but sure remain interested...
                        cheers
                          Looks like my idea isn't working as the SUp's Set has fewer methods than set.rb's Set ... F
                          So forget what I said earlier - you can have either svg.rb [with set.rb] working OR the Sandbox-Tools [and any other tools using 'Set' methods]... But not both. You must choose.
                          • dereiD Offline
                            derei
                            Any fix on that in the meantime?
                            Thanks.
                            DESIGNER AND ARTIST DEREI.UK
                              rjh5945
                              ζˆ‘ζƒ³θ¦θ―•δΈ€δΈ‹θ‘ŒδΈθ‘Œ
                              • FrederikF Offline
                                Frederik
                                Really...
                                An English forum and you didn't even bother to use Google Translate or alike...?!?
                                Please note that this plugin dates back to 2010...
                                I don't think you're going to make it work with newer versions of SketchUp...
                                Cheers
                                Kim Frederik
