Remove In Model from Components
in the components panel you have a drop down of In Model and Components is there anyway to remove In Model and have it load up straight onto the Components Folder?
Simon
No API for that, no.
@simonstaton said:
... is there anyway to ... have it load up straight onto the Components Folder?
That's the way my Sketchup opens.
Just check Components in the dropdown menu, and Sketchup will remember it.
And you cannot remove "In Model" because a user MUST be able to see and work with the components that get imported into the model.
IF there are any components placed in a SKP model when Sketchup opens you can't purge them.
Unused components can be purged... and then they are only accessible from the Components folder again...
So, unless you want to somehow explode all component instances at startup and then purge unused [=ALL], you must always have some components in the browser of any previously-used SKP, where you have placed some components ???
Register LoginAdvertisement
