    Auto-Renaming after creation of new group
    4 Posts 2 Posters 886 Views 2 Watching
      rostyk
      problem is:
      After creating and naming new group next selected object also renamed to name of new group (if new group created without name - selected object also renamed to "empty").
      Here a video of
      [flash=640,385:f4uz2wxp]http://www.youtube.com/v/MrrRqiDuHY4&hl=ru_RU&fs=1&rel=0[/flash:f4uz2wxp]
      Is a BUG or FEATURE? πŸ˜•
        I am not seeing that. Are you sure it's not some plugin interfering?
        However, I have seen other issues in regard to group/components and names:
        1. Create a component, and name the instance
        2. Create a group - an error message appear saying that the name must be unique (only occasionally occur)
        Another issue:
        Often when you click in the Name textbox in the Entity Info the Group/ComponentInstance takes on the name of the last item you named. this is similar to what you show in the video, but for me it only occurs when I click in the textbox.
          rostyk
          i use clean sketchup version without plugins
          and as you say its only occurs when I click in the textbox (i need to naming all groups and components)
            I just tried this on SU6 - same bug.
