    Scrapbooks
    layout
    8 Posts 4 Posters 1.7k Views 4 Watching
    • P Offline
      pafpro
      hello everybody!
      I have sketchup pro 7 on windows. I tried to use layout 2.1 and i had a surprise! I haven't scrapbooks dialog box!!! when i try to select it in window there isn't scrapbooks!
      really sorry for my english but is it normal?
        bjanzen
        Wow, that's weird. Try View->Restore Default Workspace and see if it returns.
        b
        • P Offline
          pafpro
          I found my problem!
          When i open c:/programfiles/google/sketchup7/layout/
          there isn't scrapebooks file! how is it possible?
          I add a scrapebooks file and find a .layout file... that works! but where can i found all the components for layout?
            Hi Sylvain,
            See this screenshot of my own PC (XP). The highlighted yellow "Csaba" is my own username on this machine; you should substitute it with your own on yours.
            These are simple *.layout files and you can practically copy anything there.
            • P Offline
              pafpro
              Thank you but i haven't this file! 😕
                Hm. These are generated automatically when you install SU. Maybe a reinstall would help? BTW what version of SU 7 do you have? 7.0 or 7.1?
                (And of course, LO only comes with SU Pro - I guess you have that).
                • P Offline
                  pafpro
                  Yes i have SU pro 7.1!
                  a friend gave me the .layout file and that works... strang! thank you for your help
                  • BurkhardB Offline
                    Burkhard
                    You also can take a search fpr scrapebooks. In the German Version there is a de file which does'nt include these files.
                    But the original path contains the scrapebook so we only have to set the right path. Maybe it is the same with you.
                    http://www.ia-plus.de
