    Glueto none?
    6 Posts 2 Posters 516 Views 2 Watching
    • thomthomT
      Error 404 (Not Found)!!1
      (code.google.com)
      Returns a constant indicating the snapping behavior of the component described by behavior. Snapping behavior is how the x-y plane of a component instance will be snapped against a face. Possible values are:
      SnapTo_Arbitrary => Snap to any aribrary face,
      SnapTo_Horizontal => Snap to horizontal face like floors,
      SnapTo_Vertical => Snap to vertical face like walls,
      SnapTo_Sloped => Snap to sloped face like sloping roofs.
      But how do one get or set if the component is set to glue to none?
      • thomthomT
        When I make two components, one which is set to None and one set to Any - then both return 0 for snapto.
        So is there some other flag?
        • TIGT
          is2d?
          • thomthomT
            No, because you can glue 3d components.
            • TIGT
              But a component that does not have is2D set will not glue ? You must set both snapto and is2D to match...
              component.behavior.is2d=true component.behavior.snapto=0
              it snaps to any surface
              but set
              component.behavior.is2d=false
              will stop it snapping to anything at all - even if snapto is set !
              πŸ€“
              • thomthomT
                Aah!
                I read only the description for Behavior.is2d?
                The is2d? method is used to get a component's 2D behavior.
                Since Behavior.is2d= is above I didn't see it's description:
                The is2d= method is used to set the 2D behavior for a component: whether it can be glued or aligned to a face.
                So is2d hasn't got anything to do with 2d / 3d size of the component - but is in fact snap and align. x_X πŸ‘Š
                Thanks TIG.
