    Orb of Light and Steel
    28 Posts 13 Posters 6.4k Views 13 Watching
    • olisheaO
      olishea
      I made this model a few weeks ago and I've only just had chance to render it. It's as high poly as sketchup will import.
      I tested various hdri environments and implemented the most complimentary scene into the render.
      Lighting is hdri only and emitters from the orbs. Sun off.
      Material is brushed steel....480 shininess with a scratchmap....0.03 bump.
      Studio backdrop is shiny plastic....300 shininess with a noisemap....0.2 bump
      Rendered with interior+ preset at 2000 pixels. DOF added in photoshop using the depth mask.
      Got more images to come!
      HDRI TESTING OPTIONS
      http://i654.photobucket.com/albums/uu269/olishea/IBL_options.jpg
      HIGH RES CROP
      http://i654.photobucket.com/albums/uu269/olishea/orb_crop-1.jpg
      FINAL IMAGE
      http://i654.photobucket.com/albums/uu269/olishea/orb_high.jpg
      Geometry Overlay
      http://i654.photobucket.com/albums/uu269/olishea/orb_geometry_black.jpg
      http://i654.photobucket.com/albums/uu269/olishea/orb_geometry_white.jpg
      Higher resolution version here:
      http://twilightrender.com/phpBB3/viewtopic.php?f=16&t=1720&p=13968#p13968
      oli
      • daleD
        dale
        very sensual object oli. Well done πŸ‘ πŸ‘ πŸ‘
        • FrederikF
          Frederik
          Great renders, Oli...! πŸ‘
          Cheers
          Kim Frederik
          • michaliszissiouM
            michaliszissiou
            Great renders indeed. πŸ‘
            This heavy topology almost killed the renderer though. This counts 10x faces more than it should. And 10x render time at least...
            • olisheaO
              olishea
              The sphere could have less faces....but the shell needs to be higher poly IMO. I tried to subdivide in wings one more time but sketchup wouldn't import the geometry properly. strange results. The renderer can handle much much more than this though. its sketchup thats the problem not twilight.
              Render time was about 16 hours πŸ˜„ the hdri was low quality giving noisy results so i had to wait wait wait!
              Got another one in the oven, macro style!
              Cheers for the comments, it was a fun one! πŸ˜„
              oli
              • artysmediaA
                artysmedia
                Like the final render! Good job! πŸ˜„
                Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
                Blog: Artysmedia
                • S
                  steelers05
                  loving the texture oli
                  • K
                    KarinaGM
                    Wow! how did you mapped that geometry?
                    The images are great! πŸŽ‰
                    **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminarΓ‘ perdiendo ambas"
                    -BenjamΓ­n Franklin.**
                    • olisheaO
                      olishea
                      Thanks very much guys!! πŸ‘ its my new screensaver lol
                      I actually used Whaat's UV tools plugin to texture. It worked surprisingly well first time. I just used spherical projection and it magically mapped the scratchmap perfectly! So many thanks to Whaat! It would have looked terrible if bumpmap was wrong. In Twilight you can easily bump a flat colour and apply a material template.
                      Watch this space, macro shot on the way πŸ˜„
                      oli
                      • jo-keJ
                        jo-ke
                        I thought whaat's plugin is "just" an exporter, to texture in an extern programm. which programm did you use to set the texture?
                        btw: your renders look really brilliant!
                        http://www.zz7.de
                        • michaliszissiouM
                          michaliszissiou
                          Not exactly jo-ke. There are more goodies there. As an exporter is not as good as the build in obj exporter of SU pro. But its an interesting project.
                          • FrederikF
                            Frederik
                            Don't know which of Whaat's UV-mapping plugins Oli have used, but based on Oli's comment...
                            ...I assume it's the [Plugin] UVTools v0.1, since it's capable of mapping a spherical object...
                            Cheers
                            Kim Frederik
                            • michaliszissiouM
                              michaliszissiou
                              I think so too Frederik.
                              • olisheaO
                                olishea
                                Yeah I textured everything in sketchup. no external app used for texturing.
                                you just set either spherical or cylindrical mapping. you can then scale the texture through sketchups material window...make it bigger or smaller depending on your needs. the UV tools menu is in........edit>surface>UV tools>Spherical Map. Just select your surface first. I think you can select the UV tools by right clicking too.
                                screens shot:
                                note: where it says "804 entities" it normally says "surface".
                                http://i654.photobucket.com/albums/uu269/olishea/Picture1-1.png
                                http://i654.photobucket.com/albums/uu269/olishea/Picture2.png
                                thanks for all the lovely comments! πŸ˜„
                                oli
                                • jo-keJ
                                  jo-ke
                                  Wow! I didn't knew that plugin. that is exactly what I'm looking for. I just started to download it.
                                  http://www.zz7.de
                                  • EscapeArtistE
                                    EscapeArtist
                                    Preeeeeeety. Shiiiiiney.
                                    Very nice! πŸ‘
                                    • olisheaO
                                      olishea
                                      Cheers mate!
                                      Here is a macro shot and a geometry overlay!
                                      http://i654.photobucket.com/albums/uu269/olishea/orb2.jpg
                                      http://i654.photobucket.com/albums/uu269/olishea/orb2_geometry.jpg
                                      FULL RESOLUTION VERSION HERE:
                                      http://twilightrender.com/phpBB3/viewtopic.php?f=16&t=1720&p=13992#p13992
                                      oli
                                      • D
                                        D-space
                                        Awesome close up & overlays. πŸ˜„
                                        http://blibestmentalt.no/54981
                                        • olisheaO
                                          olishea
                                          Cheers mate. It wasn't easy!
                                          Here is an ice finish.
                                          http://i654.photobucket.com/albums/uu269/olishea/34_small.jpg
                                          oli
                                          • FrederikF
                                            Frederik
                                            You're smoking hot with TWR, Oli...
                                            http://www.kerkythea.net/users/Frederik/Anim-Icons/thumbup.gif
                                            Cheers
                                            Kim Frederik
                                            • 1 / 2
