    Orb of Light and Steel
    28 Posts 13 Posters 6.4k Views 13 Watching
    • FrederikF
      Frederik
      Great renders, Oli...! πŸ‘
      Cheers
      Kim Frederik
      • michaliszissiouM
        michaliszissiou
        Great renders indeed. πŸ‘
        This heavy topology almost killed the renderer though. This counts 10x faces more than it should. And 10x render time at least...
        • olisheaO
          olishea
          The sphere could have less faces....but the shell needs to be higher poly IMO. I tried to subdivide in wings one more time but sketchup wouldn't import the geometry properly. strange results. The renderer can handle much much more than this though. its sketchup thats the problem not twilight.
          Render time was about 16 hours πŸ˜„ the hdri was low quality giving noisy results so i had to wait wait wait!
          Got another one in the oven, macro style!
          Cheers for the comments, it was a fun one! πŸ˜„
          oli
          • artysmediaA
            artysmedia
            Like the final render! Good job! πŸ˜„
            Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
            Blog: Artysmedia
              steelers05
              loving the texture oli
              • K
                KarinaGM
                Wow! how did you mapped that geometry?
                The images are great! πŸŽ‰
                **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminarΓ‘ perdiendo ambas"
                -BenjamΓ­n Franklin.**
                • olisheaO
                  olishea
                  Thanks very much guys!! πŸ‘ its my new screensaver lol
                  I actually used Whaat's UV tools plugin to texture. It worked surprisingly well first time. I just used spherical projection and it magically mapped the scratchmap perfectly! So many thanks to Whaat! It would have looked terrible if bumpmap was wrong. In Twilight you can easily bump a flat colour and apply a material template.
                  Watch this space, macro shot on the way πŸ˜„
                  oli
                  • jo-keJ
                    jo-ke
                    I thought whaat's plugin is "just" an exporter, to texture in an extern programm. which programm did you use to set the texture?
                    btw: your renders look really brilliant!
                    http://www.zz7.de
                    • michaliszissiouM
                      michaliszissiou
                      Not exactly jo-ke. There are more goodies there. As an exporter is not as good as the build in obj exporter of SU pro. But its an interesting project.
                      • FrederikF
                        Frederik
                        Don't know which of Whaat's UV-mapping plugins Oli have used, but based on Oli's comment...
                        ...I assume it's the [Plugin] UVTools v0.1, since it's capable of mapping a spherical object...
                        Cheers
                        Kim Frederik
                        • michaliszissiouM
                          michaliszissiou
                          I think so too Frederik.
                          • olisheaO
                            olishea
                            Yeah I textured everything in sketchup. no external app used for texturing.
                            you just set either spherical or cylindrical mapping. you can then scale the texture through sketchups material window...make it bigger or smaller depending on your needs. the UV tools menu is in........edit>surface>UV tools>Spherical Map. Just select your surface first. I think you can select the UV tools by right clicking too.
                            screens shot:
                            note: where it says "804 entities" it normally says "surface".
                            http://i654.photobucket.com/albums/uu269/olishea/Picture1-1.png
                            http://i654.photobucket.com/albums/uu269/olishea/Picture2.png
                            thanks for all the lovely comments! πŸ˜„
                            oli
                            • jo-keJ
                              jo-ke
                              Wow! I didn't knew that plugin. that is exactly what I'm looking for. I just started to download it.
                              http://www.zz7.de
                              • EscapeArtistE
                                EscapeArtist
                                Preeeeeeety. Shiiiiiney.
                                Very nice! πŸ‘
                                • olisheaO
                                  olishea
                                  Cheers mate!
                                  Here is a macro shot and a geometry overlay!
                                  http://i654.photobucket.com/albums/uu269/olishea/orb2.jpg
                                  http://i654.photobucket.com/albums/uu269/olishea/orb2_geometry.jpg
                                  FULL RESOLUTION VERSION HERE:
                                  http://twilightrender.com/phpBB3/viewtopic.php?f=16&t=1720&p=13992#p13992
                                  oli
                                    D-space
                                    Awesome close up & overlays. πŸ˜„
                                    http://blibestmentalt.no/54981
                                    • olisheaO
                                      olishea
                                      Cheers mate. It wasn't easy!
                                      Here is an ice finish.
                                      http://i654.photobucket.com/albums/uu269/olishea/34_small.jpg
                                      oli
                                      • FrederikF
                                        Frederik
                                        You're smoking hot with TWR, Oli...
                                        http://www.kerkythea.net/users/Frederik/Anim-Icons/thumbup.gif
                                        Cheers
                                        Kim Frederik
                                          D-space
                                          One nice shot for the gallery! 😲
                                            @ Olishea
                                            You have not tryed Sculptris? πŸ˜‰
                                            Seems there are possibility of some analogy with these tortuous spherical works πŸ˜„
