    Orb of Light and Steel
    28 Posts 13 Posters 6.2k Views 13 Watching
    • olisheaO Offline
      olishea
      Thanks very much guys!! πŸ‘ its my new screensaver lol
      I actually used Whaat's UV tools plugin to texture. It worked surprisingly well first time. I just used spherical projection and it magically mapped the scratchmap perfectly! So many thanks to Whaat! It would have looked terrible if bumpmap was wrong. In Twilight you can easily bump a flat colour and apply a material template.
      Watch this space, macro shot on the way πŸ˜„
      oli
      • jo-keJ Offline
        jo-ke
        I thought whaat's plugin is "just" an exporter, to texture in an extern programm. which programm did you use to set the texture?
        btw: your renders look really brilliant!
        http://www.zz7.de
        • michaliszissiouM Offline
          michaliszissiou
          Not exactly jo-ke. There are more goodies there. As an exporter is not as good as the build in obj exporter of SU pro. But its an interesting project.
          • FrederikF Offline
            Frederik
            Don't know which of Whaat's UV-mapping plugins Oli have used, but based on Oli's comment...
            ...I assume it's the [Plugin] UVTools v0.1, since it's capable of mapping a spherical object...
            Cheers
            Kim Frederik
              michaliszissiou
              I think so too Frederik.
              • olisheaO Offline
                olishea
                Yeah I textured everything in sketchup. no external app used for texturing.
                you just set either spherical or cylindrical mapping. you can then scale the texture through sketchups material window...make it bigger or smaller depending on your needs. the UV tools menu is in........edit>surface>UV tools>Spherical Map. Just select your surface first. I think you can select the UV tools by right clicking too.
                screens shot:
                note: where it says "804 entities" it normally says "surface".
                http://i654.photobucket.com/albums/uu269/olishea/Picture1-1.png
                http://i654.photobucket.com/albums/uu269/olishea/Picture2.png
                thanks for all the lovely comments! πŸ˜„
                oli
                • jo-keJ Offline
                  jo-ke
                  Wow! I didn't knew that plugin. that is exactly what I'm looking for. I just started to download it.
                  http://www.zz7.de
                  • EscapeArtistE Offline
                    EscapeArtist
                    Preeeeeeety. Shiiiiiney.
                    Very nice! πŸ‘
                    • olisheaO Offline
                      olishea
                      Cheers mate!
                      Here is a macro shot and a geometry overlay!
                      http://i654.photobucket.com/albums/uu269/olishea/orb2.jpg
                      http://i654.photobucket.com/albums/uu269/olishea/orb2_geometry.jpg
                      FULL RESOLUTION VERSION HERE:
                      http://twilightrender.com/phpBB3/viewtopic.php?f=16&t=1720&p=13992#p13992
                      oli
                        D-space
                        Awesome close up & overlays. πŸ˜„
                        http://blibestmentalt.no/54981
                        • olisheaO Offline
                          olishea
                          Cheers mate. It wasn't easy!
                          Here is an ice finish.
                          http://i654.photobucket.com/albums/uu269/olishea/34_small.jpg
                          oli
                          • FrederikF Offline
                            Frederik
                            You're smoking hot with TWR, Oli...
                            http://www.kerkythea.net/users/Frederik/Anim-Icons/thumbup.gif
                            Cheers
                            Kim Frederik
                              D-space
                              One nice shot for the gallery! 😲
                                @ Olishea
                                You have not tryed Sculptris? πŸ˜‰
                                Seems there are possibility of some analogy with these tortuous spherical works πŸ˜„
                                • daleD Offline
                                  dale
                                  If this object were ever manufactured, it would be cool to have the geometry etched into the surface. It actually really looks good.
                                  • olisheaO Offline
                                    olishea
                                    Thanks D-space (what's your name by the way?)
                                    Frederik, I think its Twilight thats smoking hot not me! It does what you expect, so easy to get good results and very stable.
                                    I forgot about Sculptris, cheers. Although I want to stay with mac only software. I HATE windows and only use it for Twilight, I will give Sculptirs a whirl though. The real daddy of these apps is Blender. I dunno why I always go for spheres, kinda majestic.
                                    Dale: Imagine polishing the surface! ooh it would be so nice. labour of love! When I go back to uni in September I will 3D print this model and place a bulb inside it. You could subdivide and smooth it further......with sandpaper πŸ˜„
                                    oli
                                    • daleD Offline
                                      dale
                                      I a job at an arts centre once (many moons ago). One of my tasks was to manage the pit fired pottery firing sessions.
                                      After you create a clay piece you polish it with a spoon as it dries (the labor of love part), then bury it in a fire pit and light her up. Although there are things that you can add that will encourage certain colors, you have virtually no control on the outcome. The orb would be a candidate for this. Made in two pieces and assembled around the light globe. Attached is an example.
                                      • Bryan KB Offline
                                        Very nice, Olishea. Wow.
                                          michaliszissiou
                                          Yeah, great last render too. πŸ‘ πŸ‘ πŸ‘
                                          You should start learning some blender too (as a mac user).
                                          • N Offline
                                            nektares
                                            Those look great oli! very nice IBL reflections!
