    Sea Level Rise Map
    14 Posts 13 Posters 1.0k Views 13 Watching
    • Mike LuceyM
      Mike Lucey
      Sea level rise map: http://flood.firetree.net/?ll=52.8446,-8.9776&z=2&m=14
      Interesting!
      • M
        MtnArch
        Very true - but it also shows Death Valley (in California) being under water, which probably WON'T happen since the nearest intrusion will be at the Salton Sea which is still a hundred miles away or so.
        Whether you believe all of the nay-sayers about what's causing global warming or not, it IS a fact that when the sea levels rise there WILL be widespread problems with where we (as world residents) have built.
        Thanks, Mike, for the post!
        Highest Regards,
        Alan T. Hendry, RA
        Architect
        • J
          john.warburton
          Hey - I'll be closer to the shore line. Maybe finally I'll get more chance to go sailing.
          Life's a reach, and then you gybe.
          • Alan FraserA
            Alan Fraser
            Excellent! A 6m rise means I can build a boat dock at the bottom of the garden. 😄
            3D Figures
            • GaieusG
              I can also do that - although that would be a long-term expectation (at 130-something metres above currentsea level)
              • pbacotP
                Thanks for the link Mike. Would that they used a more contrasting color like orange, so you don't have to be zoomed in to see prospective inundation. As you posted this centered in your area I was looking over in east England. Isn't some of that area under water half the time already? Also we have areas near us in California that are only dry because someone drained them, like Holland. Besides GCC other factors of our rivers and tidelands, the ecosystem (salmon), aging levees etc., are tending towards the end of these low lying dry areas. I think Death Valley will stay dry a while.
                • Mike LuceyM
                  Mike Lucey
                  Yeah, an orange colour would be better. My area, Ennis, Co. Clare, Ireland will be badly hit. My house will be effected with a 7m rise. An amphib might be the solution 😄
                  • dermotcollD
                    dermotcoll
                    Mike - every forum member in Ireland will now be descending on your house looking to use your corner cubby and drinking yer tae - ah ye will, ye will, ye will!!!!
                    P.S. Have you not finished it yet?!
                    When you burn your arse - you gotta sit on the blisters!!
                    • shuraS
                      shura
                      my god, New Yorck looks devastated at 14m.
                      Why is this map limited to fourteen meters? Because this would be the case when all the Ice has turned into water, or simply not to cause too much panic?
                      When I was a teen I had a comic book that told a story in a similar scenario, buildings turned into islands and the survivors were fighting for freshwater and so on. Never forgot about it because I thougt this would make an interesting set for game design...
                      bubblebubblebubble
                      • John SayersJ
                        John Sayers
                        may I suggest you read the world's foremost scientist in sea level. Dr. Nils-Axel Mörner. he's written over hundreds of papers on the subject but he is ignored because he won't follow the sheepthink that is today's global warming crowd.
                        http://www.larouchepub.com/eiw/public/2007/2007_20-29/2007-25/pdf/33-37_725.pdf
                        • pyrolunaP
                          pyroluna
                          look at my location
                          http://flood.firetree.net/?ll=51.9446,4.3776&z=6&m=1
                          surprisingly, the harbour is the one place that hasn't flooded... oh and bytheway this is only 1m rise...
                          good thing we've got dikes...
                          • thomthomT
                            ? It cuts off at about Bergen Norway... ?
                            • EscapeArtistE
                              EscapeArtist
                              We're fine until about 8 meters and then the wabter lebel buble glurb bab ob ob deeb... 😕
                              http://www.getsmileyface.com/new/fish/fish10.gif
                              • MALAISEM
                                MALAISE
                                Thanks for this quite useful link
                                MALAISE 👍 👍
