    How to add thickness to organic face?
    12 Posts 7 Posters 5.8k Views 7 Watching
    • D
      die2ad
      Hello,
      I've created a curved face with Soap Skin&Bubble plugin, but I don't know how to make it thick.
      Can anyone help me?
      Thanks.
      • Mike LuceyM
        Mike Lucey
        Hi die2ad,
        If it was me, I'd copy it, drop it and make faces along the open edges. However, that's how I would do it. I am sure others may have a better solution.
        Mike
        • D
          d12dozr
          I'd use Fredo's awesome Joint Push Pull plugin.
          Welcome to the forum! πŸ˜„
          http://goo.gl/f7ooYh
          • T
            the.pjt
            Join push pul plugin . > tab > tinking
              Else you can copy + Size
              And close the inbetween with some plug like Loft, EE by Rail etc...
              • D
                die2ad
                I know about JPP, I've tried that and the copy thing, but I thought there's better solution.
                Anyway, thanks for the replys.
                Maybe this topic should stay open.
                Again, thanks guys.
                • J
                  Jim
                  It sure sounds like JPP is what you need. Can you give a more precise description of what you need, maybe with a image?
                  • D
                    die2ad
                    Well, english is not my native language, so I can't explain cuite good what my problem is.
                    But let me try...when I extrude face with JPP, the face it self is ok, but the edges are riped and I can't edit it. Maybe there are settings in JPP that I don't know how to adjust...
                    • fredo6F
                      fredo6
                      Could you post your model, so that we can find out what is the issue.
                      Fredo
                      • D
                        die2ad
                        The face is ok, but edge is problem.
                          Post you file skp πŸ˜‰
                          • D
                            die2ad
                            I was tryin' just about everything and the best results (and the easyiest way) are when I extrude edges of curved face with "extrude lines along a vector" and then just copy the face.
