    How to add thickness to organic face?
    12 Posts 7 Posters 5.6k Views 7 Watching
      die2ad
      Hello,
      I've created a curved face with Soap Skin&Bubble plugin, but I don't know how to make it thick.
      Can anyone help me?
      Thanks.
      • Mike LuceyM Offline
        Mike Lucey
        Hi die2ad,
        If it was me, I'd copy it, drop it and make faces along the open edges. However, that's how I would do it. I am sure others may have a better solution.
        Mike
          d12dozr
          I'd use Fredo's awesome Joint Push Pull plugin.
          Welcome to the forum! πŸ˜„
          http://goo.gl/f7ooYh
            the.pjt
            Join push pul plugin . > tab > tinking
              Else you can copy + Size
              And close the inbetween with some plug like Loft, EE by Rail etc...
                die2ad
                I know about JPP, I've tried that and the copy thing, but I thought there's better solution.
                Anyway, thanks for the replys.
                Maybe this topic should stay open.
                Again, thanks guys.
                  Jim
                  It sure sounds like JPP is what you need. Can you give a more precise description of what you need, maybe with a image?
                    die2ad
                    Well, english is not my native language, so I can't explain cuite good what my problem is.
                    But let me try...when I extrude face with JPP, the face it self is ok, but the edges are riped and I can't edit it. Maybe there are settings in JPP that I don't know how to adjust...
                    • fredo6F Offline
                      Could you post your model, so that we can find out what is the issue.
                        die2ad
                        The face is ok, but edge is problem.
                          Post you file skp πŸ˜‰
                            die2ad
                            I was tryin' just about everything and the best results (and the easyiest way) are when I extrude edges of curved face with "extrude lines along a vector" and then just copy the face.
