    [REQ] Draw rectangle/square from center or center of edge
    6 Posts 4 Posters 7.8k Views 4 Watching
      Click Draw
      I haven't been on for awhile so I hope I don't embarrass myself with this post. Is there a ruby that allows you to draw a square or rectangle from the center (like the draw circle) or from the center of the edge?
      Thanks,
      Jeff
      Have I mentioned how much of a laugh I get out of some of the Signatures on here!
        Daniel S
        Fredo´s Tools On Surface can do it:
        http://forums.sketchucation.com/viewtopic.php?f=180&t=11212
        Select the rectangle tool and then you can choose the option you want on the onscreen toolbar.
        Daniel S
          Click Draw
          LOL...I guess that wasn't too embarrassing 😳 . Thanks Daniel
            d12dozr
            ...or just the native polygon tool, set it to 4 sides...
            http://goo.gl/f7ooYh
              Click Draw
              Funny how sometimes it's the simplest approach. Thanks d12dozr.
              Jeff
              • utilerU Offline
                utiler
                The only problem with this is that you only have the option to chose the centre point and the a corner [circumscribed]. What we need is the ability to select the centre point and then an offset perpendicular to an edge.
                Just Curious...
