    Evening shot
    26 Posts 12 Posters 2.8k Views 12 Watching
      davidh
      Attached is an evening shot,rendered in vray,postprocessed in photoshop
        davidh
        Attached is a revised evening shot.the bluish tint on the previous image didnt look right for the time of day so i warmed the image in photoshop.I then cropped the image as the original composition looked somewhat unbalanced.
        I also remembered to mask out 3 windows to the rear of the building where you can now see foliage.What I always try and do is get as much contrast in my images as possible,sometimes it works,sometimes it dosent.
        I will need to go back and revise the stone work as originally there was no displacement which is obvious on some of the corners.The left hand side of the stone work,above the corner window at the lower level was altered in photoshop to try to fix this.I think it partially works but it will need more work.
        • jo-keJ Offline
          jo-ke
          Wow. The second one is much better!
          http://www.zz7.de
            davidh
            Below is a rainy evening shot.all the materials had a reflective layer added (highlight glossiness 0.75,reflection glossiness 0.9,8 subdivs)The internal lighting hasnt worked as I hoped so its back to the drawing board,so to speak.
              Aidus
              Very good!
              CPU: Intel Core i7 Extreme Edition 965
              RAM: OCZ Gold DDR3 1600MHz 12Gb
              Video: Asus Radeon HD4870 X2 2Gb
              Mobo: Asus P6T Deluxe 1366 Intel X58
              • F Offline
                fymoro
                OMG, This last image remind me when I was in England last year πŸ˜† πŸ˜‰
                Very nice render... πŸ‘
                http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
                • massimoM Offline
                  massimo Moderator
                  A great image the last πŸ‘ It's a pity that some materials (especially the wood, the stone and the roof on the left) and the interiors look a bit flat. The oxidated copper and the foreground vegetation are superb.
                  • RichardR Offline
                    Richard
                    David - mate brilliant job there!!!!!!
                    The last image! Love evening rain shots, did you post pro the drops? For me a little less dense or in reality you may be expecting spray from the buildings and water running on ground. and given night shot (slower speed) the drops would be much longer - maybe 1/4 depth of image but also faint so not to obstruct (they aren't in one spot long enough to get enough exposure) - hope all makes sense mate?
                    BUILTBRAND.COM.AU
                    • pyrolunaP Offline
                      pyroluna
                      Whow real nice shot, davidh! You don't see a rainy shot that often!
                      I really like the mood - it makes me imagine it must be really cozy indoors πŸ˜„
                      Also the composition of the rainy shot is much better than that of both preceding images.
                      However I do agree with massimo about the flatness of some materials; the added reflectivity emphasizes this even more.
                      • Bryan KB Offline
                        My jaw is starting to hurt from all the great renders I'm seeing here.
                        The rainy evening render is absolutely incredible.
                          davidh
                          A small bit more water ...
                          • dermotcollD Offline
                            dermotcoll
                            Now it does look like a typical summers day in Ireland!!!
                            When you burn your arse - you gotta sit on the blisters!!
                            • honoluludesktopH Offline
                              honoluludesktop
                              Wow, not bad for a summers day:-)
                              Well, I like the contrast range of the second image, especially on the rock wall, but not the colors (I know its a suppose to be a evening render), but I pp it as a daytime one:Uerrace_hazy_4tics_6059sec.jpg
                              I especially like the grass at the base of the tree in the foreground, and the use of trees in the mid ground. I would have added people on the deck, perhaps children playing.
                              • RichardR Offline
                                Richard
                                Oh mate that last shot is GREAT!!! Good on ya!!!
                                Reminds me of once a builder mate of mine had a 18,000 litre water tank colapse and flood an elevated hillside house - the engineer had designed the tanks stand though only allowed for 5,000 litres and lost his butt as the house was then complete and habitated!
                                BUILTBRAND.COM.AU
                                • massimoM Offline
                                  massimo Moderator
                                  Really love the last one! πŸ‘ πŸ‘
                                  @Richard 🀣 Btw I hope that there weren't serious problems for people... πŸ˜•
                                    dermotcoll
                                    @massimo
                                    Not if you dont regard flooding and homelessness as serious problems!!! 🀣
                                      skyscraper100
                                      coolness! i like it a lot especially the 2012 effect lol. gjob πŸ‘
                                      The way you think Creates reality for yourself.
                                        davidh
                                        attached is a winter shot using the same visopt as for the summer evening shot.the only thing difference is that I used a different treeline in the foreground to cast shadows on the house.But this didn't work as I hoped as the shadows from the trees still have a lot of foliage indicated.Ill do a re-render with more winter type trees.The real benefit is that all the snow,planting,sky etc is all on individual photoshop layers so once I have the new render done it is simply a matter of dragging and dropping the render image into the photoshop file,with some small colour correction.
                                        I am working on an Autumn scene using the same elements and hope to upload next week.
                                          robert111
                                          very nice davidh
                                          how you made the waterfall , with brush photoshop
                                          can you make tuto for this , I am trying to find this tutorial
                                          thanks davidh
                                          • RichardR Offline
                                            Richard
                                            Your smokin now mate! I'm wanting for the war scene! MORE! Lovin!
                                            BUILTBRAND.COM.AU
                                            • 1 / 2
