    Translate My Documents
    18 Posts 5 Posters 1.8k Views 5 Watching
      Jim
      I think on Windows I can get the user's folder by using:
      user_dir = ENV['USERPROFILE']
      But on Spanish language of Windows, "My Documents" is "Mis documentos" (I think.) How do we get the language-corrected folder name (or path) for "My Documents"?
        Norwegian Vista 32bit system:
        ENV.each{|k,v|puts "#{k} - #{v}"} ALLUSERSPROFILE - C:\ProgramData APPDATA - C:\Users\Thomassen\AppData\Roaming CLASSPATH - .;C:\Program Files\Java\jre1.6.0_05\lib\ext\QTJava.zip CommonProgramFiles - C:\Program Files\Common Files COMPUTERNAME - LAPTOP ComSpec - C:\Windows\system32\cmd.exe FP_NO_HOST_CHECK - NO HOMEDRIVE - C: HOMEPATH - \Users\Thomassen LOCALAPPDATA - C:\Users\Thomassen\AppData\Local LOGONSERVER - \\LAPTOP NUMBER_OF_PROCESSORS - 2 OS - Windows_NT Path - C:\Program Files\PC Connectivity Solution\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\PROGRA~1\COMMON~1\ULEADS~1\MPEG;C:\Program Files\QuickTime\QTSystem\ PATHEXT - .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC PROCESSOR_ARCHITECTURE - x86 PROCESSOR_IDENTIFIER - x86 Family 6 Model 15 Stepping 13, GenuineIntel PROCESSOR_LEVEL - 6 PROCESSOR_REVISION - 0f0d ProgramData - C:\ProgramData ProgramFiles - C:\Program Files PUBLIC - C:\Users\Public QTJAVA - C:\Program Files\Java\jre1.6.0_05\lib\ext\QTJava.zip SESSIONNAME - Console SystemDrive - C: SystemRoot - C:\Windows TEMP - C:\Users\THOMAS~1\AppData\Local\Temp TMP - C:\Users\THOMAS~1\AppData\Local\Temp USERDOMAIN - Laptop USERNAME - Thomassen USERPROFILE - C:\Users\Thomassen windir - C:\Windows
        I don't see anything that relates to the Documents folder...
          If you are ok by depending on the win32 module: http://blade.nagaokaut.ac.jp/cgi-bin/scat.rb/ruby/ruby-talk/203409
            USERPROFILE gives you the partial path then use /My Documents/ or the equivalent of each locale - you'll need to construct a 'lookup-table' based on the 'locale'... ๐Ÿ˜•
              The problem here is that even getting the system locale is a problem. Same problem I've struggled with in regard to number formatting and parsing.
                http://code.google.com/apis/sketchup/docs/ourdoc/sketchup.html#get_locale
                finds the Sketchup locale which is a good start - if the users installs a non-locale version it's a pain BUT you could use the look-up table to check if a folder exists, based on a default and a locale, and if nothing is found then pop-up a dialog asking for the path to the the 'My_Documents' folder ?
                or if it's always on a PC then hack the registry use 'cmd' etc:
                HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders String value: Personal
                which will return the path to the 'My Documents' folder in any locale...
                ๐Ÿ˜•
                  @tig said:
                  http://code.google.com/apis/sketchup/do ... get_locale
                  I use Norwegian locale, and there is not Norwegian SU. I use English SU and Sketchup.get_locale returns "en-US". It can not be relied on to represent the system locale. SU isn't localised to that many languages.
                  I think this is what this does:
                  @thomthom said:
                  If you are ok by depending on the win32 module: http://blade.nagaokaut.ac.jp/cgi-bin/sc ... alk/203409
                    I think this is becoming too complex...
                    Just make a temporary cmd file in Ruby, then 'openURL' it to read the Registry entry and then write it into a temporary file, that you then read using Ruby to find the path to the current user's 'Documents' folder ?
                      Jim
                      On the person's computer, ENV["USERPROFILE"] returns:
                      "C:\Users\Jim"
                      When the location is:
                      Doctored Image
                      What is Equipo? Is it "My Computer"?
                      (I will now re-read the thread and see what I missed.)
                        Jim
                        Just FYI, there is a User Shell Folder key because, from the article (2003)..
                        the "Shell Folders" key exists solely to permit four programs written in 1994 to continue running on the RTM version of Windows 95.
                        The gist of the article is do not rely on registry keys directly and use the system library to read the location of the special folder names. The article is aimed at Windows application developers, but it applies here because reading these registry keys isn't giving the desired result.
                        HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
                        Which in my case looks like this:
                        But from my previous post, it would not return the desired path either. The real directory name is Usuarios, and not Users.
                        (My Google skillz rulez!)
                        • Chris FullmerC Offline
                          Jim, did you do a full install in spanish? OR just change the language to spanish on your existing system?
                          All my Plugins I've written
                            Jim
                            Neither, it's not my computer.
                            Right now, I think the answer is in using Win32API, but need to learn to use it make the system call.
                            The Dir::PERSONAL would probably work, but there are more than a few dependencies, and it complains about the Ruby Version being 1.8.0 (in SketchUp) instead of my installed 1.8.6, so I can't get it to work easily.
                            Update: I think I found a single-file (or 2-file) solution. Test pending...
                            • Dan RathbunD Offline
                              Dan Rathbun
                              @tig said:
                              ... or if it's always on a PC then hack the registry use 'cmd' etc:
                              YES, what TIG said! ๐Ÿ‘
                              Because I "think" XP and earlier used "My Documents",
                              and Vista (v6) and later (Win 7) uses "Documents" (more like UNIX, Linux and OSX.)
                              I'm not sure when the change occurs for Windows Server versions.
                              (a) You can call Reg.exe either thru a back-quoted string or IO.popen
                              (b) Use the standard Ruby library for Windows Registry
                              ENV['RUBYLIB'+'/lib/win32/registry.rb']
                              which relies upon Win32API.so
                              def get_docs_dir
                                @dir=''
                              if RUBY_PLATFORM.include?('mswin')
                                reglib = ENV['RUBYLIB']+'/lib/win32/registry.rb'
                                if test( ?e, reglib )
                                  require reglib # require uses absolute paths before iterating $;
                                  key = 'Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders'
                                  Win32;;Registry;;HKEY_CURRENT_USER.open( key ) do |reg|
                                    @dir = reg['Personal']
                                  end # let block end normally so key gets automatically closed
                              else
                                raise( NotImplementedError, 'Not a Windows Platform' )
                                return @dir
                              end # def
                              EDIT: changed string append to concat in line 4
                              I'm not here much anymore.
                                require 'win32dir.rb' true p Dir::DESKTOP "C:\\Users\\Thomas\\Desktop" nil p Dir::PERSONAL "C:\\Users\\Thomas\\Documents" nil p Dir::APPDATA "C:\\Users\\Thomas\\AppData\\Roaming" nil p Dir::LOCAL_APPDATA "C:\\Users\\Thomas\\AppData\\Local" nil
                                  Dan Rathbun
                                  @thomthom said:
                                  [ruby]require 'win32dir.rb'
                                  Where do you get 'win32dir.rb' ??
                                  Looks like a Windows extension to the Dir base class.
                                    Jim
                                    I'm almost sure it is from win32utils, but it must be an earlier version because the current version of the file has changed considerably.
                                    The current version has a list of dependencies on other libraries, while this version only requires win32api.so
                                    I've attached the version here that relies only on win32api.so
                                    I'd be interested if it returns the localized names of Dir::PERSONAL, et al.
                                    dir.rb
                                      I think that on Vista/W7 they changed the windows folder to always be in English, but with an aliasing scheme for presenting them localized to the user in some cases. (I'm a bit confused on how it really is set up.)
                                      But on XP the folder names for sure is localised. I can try later today on my old laptop with Norwegian XP.
                                        Jim
                                        Hopefully, this file will work. It uses the system call ShGetFolderPath or ShGetSpecialFolerPath to retrieve the folder, so maybe the paths will be localized.
                                        I'd be interested to see if it works.
