    What what what? This makes no sense!
    6 Posts 3 Posters 1.1k Views 3 Watching
      Save the following snippet into a test module in your plugins folder.
      Draw some shapes in SU and select everything. (have some groups/comps)
        def self.test
          model = Sketchup.active_model
          ents = model.selection.to_a
          arr = []
          until ents.empty?
            e = ents.shift
            next unless e.is_a?(Sketchup;;Edge)
            arr << e.all_connected.to_a.select{ |entity| entity.is_a?(Sketchup;;Edge) }
          arr.length
      When you run the snippet, which does nothing but create some arrays, the loose geometry appears to deselect. But they are in fact selected, which the Entity Info displays. You can even use the move tool for instance and see that everything is moved.
      It all boils down to this line:
      arr << e.all_connected.to_a.select{ |entity| entity.is_a?(Sketchup::Edge) }
      But why? It makes no sense.
      I see this on SU 7.1, Windows and OSX. It's maddening!
        I slimmed it down further:
          def self.test
            e = ents.shift
            e.all_connected
        If you have three separate squares in your model selected when you run this, then one will appear to be unselected afterwards.
          Glitch in the API somewhere - until it's fixed perhaps you can add model.selection.add(ents) near the end to ensure the original selection stays highlighted ? πŸ˜•
          • Dan RathbunD Offline
            Dan Rathbun
            .add and .remove are just aliases for .toggle
            So did I, the culprit is the .all_connected methods for Face and Edge classes.
            module Select_Test
              def self.go
                view = model.active_view
                sel = model.selection
                sfc = sel.first.all_connected
                view.refresh
                  # the first square unhilites
                UI.messagebox('Ready to Re-Hilite the square.')
                sel.toggle sfc  # removes from the selection
                sel.toggle sfc  # adds back into selection
                view.refresh
                  # the first square REhilites
            end # module
            P.S.: I AVOID using "test" as a method name because of the importance of Kernel.test which all objects inherit.
            I'm not here much anymore.
              Dan Rathbun
              @thomthom, is this still a bug, or has it been fixed ?
                hm...
                I don't recall this thread at all any more. But I tried this in SU2016, and it seem to be doing something odd. In my test a group would be deselected after running this code and making a zoom to update the viewport.
