    Help with VISMAT please...
    renderpluginsextensions
    4 Posts 2 Posters 2.9k Views 2 Watching
    • kaluK Offline
      kalu
      Hi to all:
      I am new in VRAY for sketchup and I use the new version 1.48 PC, when I load some Vismat materials to the scene some materials come with a JPG. Where do I have to load that JPG?...I am lost they have alot of "M" materials and I do not know where is the correct place....
      this is the link to the sample of material that I have no clue how I can use the VISMAT and place the JPG attached...
      http://www.yousendit.com/download/dXFXaklxV3IwMEUwTVE9PQ
      Thank you.
      Concrete sample...
      THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
      • broomstickB Offline
        broomstick
        look for diffuse and bump channels. Click on the little m on the right, select Bitmap from the drop down menu that appears and then load the immage. You should have two images, one with diffuse in the name, one with bump. The first goes in the diffuse channel, the second in the bump channel πŸ˜„
        • kaluK Offline
          kalu
          Thank you for the ASAP response. I want to know where I can find this material:
          http://www.vray-materials.de/all_materials.php?q=Polycarbonate+panels&Submit=Search
          is a Polycarbonate Panel translucent white, and I can't convert that to vismat for sketchup any help?....
          Thank youuuuuuuuuuuuuuuu!!!!! β˜€
          • kaluK Offline
            kalu
            PLEASE, any help with this material....Does anyone can step up and help pleaseeeeee!!!!
