    Plugin Help!!! it seems so simple but....
    7 Posts 3 Posters 1.1k Views 3 Watching
    • cmeedC
      cmeed
      I have been pulling my hair out! it seems so simple but i cant get it right? is there a plugin that will do the following (see pic)
      its basically the same shape, but ones a different length, and they twist.
      it is the end of an arm rest and i spent far too long attempting to get a plugin to work. in the end i used TIGs extrude by rails although making a rail for it to travel on was difficult, it got squashed on the was round and i had to change some straight lines to curves to get this attempt. (on right) and its really twisted around the back.....
      Please help.....
      • B
        Builder Boy
        Have you tried 2 faces + Path?
        http://forums.sketchucation.com/viewtopic.php?f=323&t=21658
        All my plugins
        • jeff hammondJ
          jeff hammond
          can you post the .skp?
          dotdotdot
          • cmeedC
            cmeed
            skp......
            plugin help.skp
            • cmeedC
              cmeed
              this looks good thank you...... i'll have a go when i'm at work.
              • cmeedC
                cmeed
                nearly!!! the last one nearly got there, its the final alignment of the two shapes thats not right. maybe more tinkering.
                • B
                  Builder Boy
                  Can you post the plugin? It looks fun and useful.
                  All my plugins
