    Something wrong with my exported piranesi epixfile
    5 Posts 4 Posters 502 Views 4 Watching
    • Q Offline
      qwerter
      Hello,
      I exported a epixfile for use in piranesi but am running into a problem.
      When I select a different style in sketchup then the ones that come with the program I end up with a bad epixfile.
      The styles I would like to use are the Sketch styles by spdesign (http://forums.sketchucation.com/viewtopic.php?f=40&t=9749&hilit=styles), but as you can see none of them result in a good epixfile.
      Im using Sketchup 6 and piranesi 5.1 the sketchupfile is a urban planning map and in 2d, totally flat.
      anybody any suggestions?
      • Mike LuceyM Offline
        Mike Lucey
        Hi qwerter,
        I have asked the Piranesi guys to look at the problem. I expect one of them will be in touch.
        Mike
          steel.monkee
          @qwerter said:
          Hello,
          Bad epix export? Could you describe it further?
          Kapag maiksi ang kumot, matutong mamaluktot.
            arvan
            Hello Qwerter,
            I'm one of the Piranesi developers. I can't see what is wrong, please can you explain exactly what the problem is. If you want to email me the epix file I'm happy to take a look at it.
            I've PM'd my email address to you.
            Arvan
              arvan
              Qwerter sent me some data, and the problem reproduces for me with SketchUp 7.1.
              I've recommended reporting it to Google. Until they fix it you can work around it by also exporting to PNG format and importing that image into Piranesi.
              Arvan
