    How I can fix this problem
    8 Posts 4 Posters 487 Views 4 Watching
    • bagateloB Offline
      bagatelo
      I try to import this DWG file into Sketchup, but
      it comes without faces. Someone already knows the way
      to fix this problem ?
      Please download the file below, and try to import into
      Sketchup.
      3d.rar
      • X Offline
        xrok1
        i'm going to go out on a limb without downloading the file and say that its too small for SU to create faces. try scaling it up before trying to import it. if i'm wrong 😳
        “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
        • honoluludesktopH Offline
          honoluludesktop
          Any chance you can post a small sample of your file as a dxf (just rename the extention .txt) so that we can see what your entity types are? Su faces are created from closed ACAD 3d polylines. So, my guess is that your file entities may be lines. Btw I can't open .rar files.
          • bagateloB Offline
            bagatelo
            THANKS!!!! I scale up the file in another aplication before import into sketchup, and works fine. THANKS!!!!
            • X Offline
              xrok1
                honoluludesktop
                  You could also ensure that the SUp import units [set under options] matches the original DWG's units - otherwise it can become too small anyway... 😒
                  • bagateloB Offline
                    bagatelo
                    YES!!! it works too. Thanks.
