    Is Point between Points?
    10 Posts 3 Posters 610 Views 3 Watching
      Given three points A, B and C which are co-linear, what is the best practice way to determine if C is between A and B?
      I searched the net and there appear to be various solutions, but there is the question of dealing with precision errors...
        I hacked together this:
        def self.point_between(a, b, c)
          v1 = c.vector_to(a)
          v2 = c.vector_to(b)
          return true if !v1.valid? || !v2.valid?
          !v1.samedirection?(v2)
        How bad is that?
          RickW did something...
          point1.between?(point2,point3)
          Not sure where it is ...
            cjthompson
            Do you know why just comparing the individual X,Y and Zs won't work?
              Like how?
              I'm curious in terms of performance and accuracy.
                Here's one of several examples that are around
                class Geom;;Point3d
                  def between?(pt1, pt2, cond)
                    # original idea by RickW
                    # self is the point3d to test
                    # cond if true returns true if self is at and end point, pt1 or pt2
                    # cond if false does not include for self on an end point, pt1 or pt2
                    # returns true if self is on the line between pt1 and pt2
                    # returns false if not.
                    d1 = self.distance(pt1) + self.distance(pt2)
                    d2 = pt1.distance(pt2) + 0.0
                    if (d1 <= d2) || (d1-d2 < 1e-10)
                      if cond
                        return true
                      else
                        return true if self != pt1 && self != pt2
                      end#if
                    end#if
                    return false
                  end#def
                end#class
                  1e-10 - is that the tolerance?
                  I refined my previous hack. I have tried this method in hopes that the tolerance in the methods used makes for a result that matches how SU works. But I'm not all too sure. And I have not benchmarked it.
                  # Checks if point C is between line segment AB.
                  # Uses Sketchup methods to match it's accuracy. (Reliable?)
                  # Compares the vectors from C to A and B. Assumes Zero vector means that C
                  # is on the same point as A or B, which counts as 'between'.
                    v1 = c.vector_to(a)
                    v2 = c.vector_to(b)
                    return true unless v1.valid? && v2.valid?
                    v1.samedirection?(v2.reverse!)
                    Btw, here is one of the links I looked at while reading up on this: http://stackoverflow.com/questions/328107/how-can-you-determine-a-point-is-between-two-other-points-on-a-line-segment
                      cjthompson
                      @TIG
                      You should probably convert d1 and d2 to float before comparing them:
                      0.0001.inch == 0.001.inch #=> true
                      BTW, do you have to determine whether the point is on the line, or is it just assumed?
                        cjthompson
                        something like this:
                        def pointBetween(a,b,c)
                        	array = [[a.x.to_f,b.x.to_f],[a.y.to_f,b.y.to_f],[a.z.to_f,b.z.to_f]]
                        	x = c.x.to_f.between?(*array[0].sort)
                        	y = c.y.to_f.between?(*array[1].sort)
                        	z = c.z.to_f.between?(*array[2].sort)
                        	return x && y && z
                        I'm not saying it will work, I'm just wondering whether it will or not.
