    Drape error
    7 Posts 3 Posters 442 Views 3 Watching
    • coulteriC Offline
      coulteri
      Hello!
      I´ve got a problem with drape tool. I have quite large flat terrain and when I drape some lines onto it, not all of them appear....
      Have you any ides, why this happens a how to fix it?
      thaks
      coulteri
        I've also seen this behaviour. Would be nice to know why not all edges drape properly.
        • mitcorbM Offline
          mitcorb
          Probably the inherent precision limits of the program. Supposedly overcome by temporarily scaling up the model to some unspecified extreme proportions. Maybe not- just speculation.
            No - it's not small edges that are missing. Edges meters long.
            • mitcorbM Offline
              mitcorb
              Yes, but what about tiny variations in gradient for lines meters long?
              • coulteriC Offline
                coulteri
                I found some errors in file with lines and this file was imported from dxf format. I´m not autor of it. Some lines were not joint, sometimes there were small lines over the intersections. Could this be the problem?
                • mitcorbM Offline
                  mitcorb
                  coulteri:
                  Yes, most likely either the dxf or the import process.
                  I am not the expert here, but what I have learned is that the original dwg or whatever, needs to be cleared of stray z values. This happens when the original drafter unintentionally or otherwise failed to snap vectors to appropriate endpoints, midpoints etc.
                  There is a thread or two here involving best practices for import dxf's and how to prepare them.
