πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Problem with 1.05.03
renderpluginsextensions
30 Posts 3 Posters 3.4k Views 3 Watching
    sepo
    As I said before no problem rendering in Podium and Twilight.
      They might be loading the textures embedded into SU. V-Ray tried to open the original files.
      Try to open the files in an image editor.
        sepo
        I opened texture files in CS3 from SU (context click)...dumped tmp files and no change.
          No - try to open the files from the location VfSU reports it tried to load them from.
            sepo
            hmm program data is hidden ...how do you reveal it? 😳
              dkendig
              The problem is that the materials have their textures set to external files. If you look at the path for the bitmap texture used in those materials in the V-Ray material editor, you should see for example: "C:\Users\s porobic\Desktop\Water Textures\untitled.bmp" is set for one of your textures. If you have an external file set like that, the file needs to exist at the location specified in the file path. It isn't going to look in the SU scene for the texture, and automatically extract it before a render, because you are telling V-Ray that you don't want to use that image for the texture, you want to use an external file. Your render progress window is telling you that those files are not accessible, so either those files don't exist at the specified path, or V-Ray does not have permission to access those files.
              Devin Kendig
              Developer
                Try the one not in program data first:
                Bitmap file "C:\Users\s porobic\Desktop\Water Textures\untitled.bmp" failed to load: cannot open file
                  sepo
                  right..the file is not there....what do you suggest that I do?
                    Relink the textures. Open the material editor and load the textures from disk again. You might have to save them to disk from SU unless you don't have the original files somewhere.
                      sepo
                      Thanks a lot for your help. πŸ‘
                      • 2 / 2
                      2 / 2
