    Font changed
    layout
    3 Posts 2 Posters 1.1k Views 2 Watching
      redinhawaii
      I had some issues with a document, it was sent to one of the moderators and it was fixed, when it came back the fonts had changed.
      I have not found a way to within that specific document, revert back to the original fonts, sizes and types
      There should be a way to do this "globally" within that document rather than having to go to each example and change that by hand.
      If I do a "select all" it also changes the font size and type (i.e. bold or not)
      thanks
      aloha
      red
        bjanzen
        FYI to others (sent this to Red): Most of the time you can select the items that get the same fonts, and use the one-shot (type "s") sampler to change all of them. Or select all and use the font panel. In his model's case, I thought I knew why it wasn't changing all, but that was in error. I'm still trying to understand it. When I figure it out, I'll post.
        The issue was Red was using a font that I don't have on my system, which would be fine normally, but I wanted to make sure all models were rendered properly, so after opening the file on my system, I re-rendered all models and saved the file. That saving now gave him my font substitution for the missing font.
        I e-mailed Red, and I can fix that for him.
        b
          redinhawaii
          thanks
          I really really appreciate the help.
          aloha
          red
