    [help]Group component instances
    4 Posts 3 Posters 355 Views 3 Watching
      sm4rt
      I'm beginner in SketchUp Ruby coding and in fact I've never code into Ruby... (only C++ PHP JavaScript skills)
      Well I load and place some components using a "for" loop
        for i in 1..numberP
          point = Geom;;Point3d.new x0,y0,z0
          transform = Geom;;Transformation.new point
          model = Sketchup.active_model
          entities = model.active_entities
          path = Sketchup.find_support_file "mymodel.skp" ,"Components/"
          definitions = model.definitions
          componentdefinition = definitions.load path
          instance = entities.add_instance componentdefinition, transform
          # Calculate next panel corner for next loop.
          numinraw = num % numbyraw
          if (numinraw==0)
            x0 = abscisseRaw * rawNum
            y0 = ordonneeRaw * rawNum
            rawNum += 1
          else
            x0 = x0 + abscisse
            y0 = y0 + ordonnee
          num += 1
      And after that I want to group theses componentdefinition in order to apply them some other transformation...
      I imagine placing a line like "group = model.active_entities.add_group" just after the instance declaration or selecting all instances after the loop...
      But it does not work certainly due to the group declaration and the way I want to add components inside after
        Before the loop set up an empty array
        instances=[]
        Within the loop after you've set instance push it into instances
        instances << instance
        After the loop
        group=model.active_entities.add_group(instances)
        Note: you could define entities outside of the loop and then reuse it - stuff you define in a loop is not accessible outside of it...
        πŸ€“
          sm4rt
          oh nice! thank you for it and for your note... (really need to study ruby first I think)
          I've just to transform it now with two rotations but only the last one work in fact. if you got a lil tip for it... I'll calculate the resulting vector and angle of the two transform I need that's pretty strange...
            MartinRinehart
            In addition to TIG's info, you should move all the one-time code outside the loop.
            I also heartily recommend that you use four-space indentation in spite of the fact that two spaces is a Ruby convention. Four is much more readable which is why it is mandatory in Python, convention in C++, Java, JavaScript, ... (every language I know, except Ruby).
            New languages are always a PITA. Fortunately, quite a small subset of Ruby is all you really need to create SketchUp plugins.
            Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
