    Adding a sketch plan to vray render
    2 Posts 2 Posters 307 Views 2 Watching
    • L
      leehanrahan
      i would like to know how i can add a jpeg image of a plan under my render, when ever i do a render in vray it is not there, can anyone help
      • thomthomT
        I'm guessing you are not using the latest V-Ray for Sketchup and the jpeg texture you try to render is an Image. (It says Image in the Entity Info window when you select it?)
        Before v1.48.66 of VfSU it did not render Image elements. You have the explode it.
        We have a V-Ray section here at the forum: http://forums.sketchucation.com/viewforum.php?f=322
        And please mention what version of VfSU when asking question as the answer often depends on this.
        Also: screenshots of your SU model and your test renders greatly help when answering. If you have a small test model then you can add that to the post as well.
