    Help for a newbie
    12 Posts 3 Posters 750 Views 3 Watching
      sargunster
      Heres my model:
      Model
      You will see that one of the outside walls has more lines than the rest. I want to copy those lines to the rest of the outside walls. Is there any fast way to do this? Maybe using the follow me tool?
      BTW: why's the new topic button all weird?
      EDIT: Same with the post reply button...
      • X Offline
        xrok1
        1 go to top view and make a rectangle bigger than your house, dbl-click then group it, move/copy it up snapping it to each line level
        2 triple click house, intersect with model
        3 delete all rectangle groups 😄
        “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
          sargunster
          On mine it made the lines on the inside too...
          • X Offline
            xrok1
            you could cut a hole in the rectangle first if you want to get fancy. 😉
              sargunster
              Ok, I got the lines copied, now I made the original wall more detailed and I want to make the other walls like that. All the outside walls that are part of the main decagon should get that design. How do I do that?
              Updated model with another wall done to show you what I mean. I'm doing this manually right now, but still looking for a faster way.
              globe2.skp
              • X Offline
                xrok1
                this is actually how the whole thing could/should have been built (when building something symmetric its a good way to work)to start with but...
                1 delete sections but one, make the remaining one a group (or component if you want future edits to auto update all sections)
                2 find the center of the decogon, select and use the rotate/copy tool to copy the first section adjacent to the first
                3 type x11
                  sargunster
                  is there a single tool called rotate/copy or do I use the 2 separate tools?
                  • X Offline
                    xrok1
                    use the rotate tool and press ctrl so you see a plus beside it just like the move tool.
                    • X Offline
                      xrok1
                      if you look at my image2 in my other post you'll see the plus sign.
                        sargunster
                        Alright, thanks. It ended up a bit weird, but I fixed it. 😄
                        • david_hD Offline
                          david_h
                          Forsooth. Methinks thou art modeling yon Globe theater. I attend on your results with aniticipation rife with Joy. Zounds!
                            sargunster
                            Yeah it's an extra credit project for lit class
