    Best OBJ import plug-in.
    5 Posts 4 Posters 953 Views 4 Watching
      sunburned_surveyor
      Can anyone recommend what they feel is the best OBJ format import plug-in. I know I have seen a couple different plug-ins, and was hoping for some feedback on those Sketch-Up users that have tried them.
      Thanks for the suggestions.
      The Sunburned Surveyor
        Jim
        I think TIG's is the latest and greatest:
        http://forums.sketchucation.com/viewtopic.php?f=323&t=20584
          Although that does fail on some obj file formats - e.g. where the vertices and faces are not tabulated together - however, opening these obj's in MeshLab [free] and exporting them as .dae lets you then import into SUp successfully...
            tomot
            Its also worth noting that Meshman another [free application], has some very good remeshing options.
            [my plugins](http://thingsvirtual.blogspot.ca/)
            tomot
              sunburned_surveyor
              Thank you for the suggestions. I downloaded the plug-in from TIG and got it to work rather well with some sample OBJ files. I'm going to study his code to see if I can tweak some things for my own OBJ import needs.
              I also appreciate the reference to meshlab. I'll download and install that so I have another program in which I can test the OBJ files I am creating.
