    [Plugin] RayTrace & RaySpray
    46 Posts 23 Posters 74.8k Views 23 Watching
    • F Offline
      flowheimer
      @thomthom said:
      Does it happen in SU7?
      There is a bug in the raytracing function in SU8.
      It seems to work in SU7.
      Guess I'll use 7 till it works in 8.
      Thanks!
      fH
        An impending maintenance release for v8 might help with ray-tracing...
          mjm6x9
          This is just the plugin I've been looking for!
          I work for a dedicated acoustic consultancy firm and this is incredibly useful for small room acoustics projects.
          I've several ideas on improvements, but just want to know if you are going to be developing this further in the near future?
          Or what would be the possibility of buying the existing code from you and looking to develop it further ourselves??
          The things I'd like to see developed are:
          1. Specification of number of reflections in RaySpray (1st, 2nd, 3rd order etc)
          2. Different coloured lines to display reflection order (e.g. 1st reflection blue, 2nd reflection green)
          3. limit RaySpray to particular rotation angle, i.e. currently it runs through 360 degrees but could it be set to only run through 90 degrees)
          4. Would it be possibly to highlight the reflecting surface when using RayTrace in order to easily establish which surface you are reflecting off (this is difficult to visualise currently)
          5. Possible option of setting specific reflecting surface (maybe using Layers) so that reflections only occurred off these surfaces when using RaySpray
          Look forward to hearing from you
            BrooksL
            Wow TIG - I've been looking all over for a tool like this for a couple weeks! [I avoided the keywords ray trace because it turns up lots of results for rendering]
            I need such to tool to look at angles of reflection and reflected angles for laser beam vision systems with mirrors - because figuring the angles manually can get quite tedious! Thanks!
            A few bug/issues I'm finding with V1.2 20100326 - using in SketchUp 8 Pro 8.0.11752 -
            Sometimes a ray will not reflect; the second point selection was an intersection of guidelines on a plane, but it wasn't reflecting from that point until I deleted the existing guides and guidepoints in that area and re-drew them (the original guides and points were indeed on the plane).
            I don't see the magenta preview ray.
            Seems to use a lot of CPU resources to during point selection - noticeable lag in following the mouse, but maybe that's just the SketchUp api.
            With RaySpray;
            The cursor inference point indicator is not showing up.
            Some of the rays do reflect -- and stop when they hit an original sprayed ray -- and original rays stop when they hit a reflected ray. (sample file attached)
            Still, this is a REALLY helpful plugin! Thanks, TIG!
            [to help others find these helpful plugins, some additional keywords: Reflected Angle, Reflected Ray, Angle of Reflection, Beam Reflection, Beam Reflect, Reflection Guide ]
            RaySpray V1.2 erratic in SketchUp 8.0.11752
              lydfa
              Great plugin!
              Thank you very much.
              Cheers,
              Dennis
              • Z Offline
                zlitalien
                TIG, this has been a great tool to use! I'm wondering if there's a way to make the ray auto adjust in real time if you move the object its reflecting off of?
                • 3 / 3
