    Delete object with script?
    12 Posts 5 Posters 2.3k Views 5 Watching
    • H Offline
      hpnisse
      Hello!
      As the title say, I wonder if there is some way to delete objects with a script or something?
      example: If "Box A" touched "Box B" the "Box A" will be deleted!
      An ontouch script that delete everything that it touch, not just specific objects.
      Hope someone can ask and understanding my english.
      Thanks!
      /hpnisse
      ** %(#BF0000)[/hpnisse]**
      %(#000000)[Windows 7 U] %(#000000)[-]%(#408000)[Sketchup 8] %(#000000)[-]%(#4000FF)[SketchyPhysics 3.2-Dec2] - from Sweden
      • H Offline
        hobbnob
        It is, but not reccomended as noone has yet made a script to get the deleted objects back after the simulation.
        My WIP Thread:Here
        • H Offline
          hpnisse
          ok, thats okej, cause the objects that touch "Box B" should not appear again after the simulation, the model I working on is a scripted bowling alley.
          The pins are emitted down on to the lane, and when a ball pull the pins down and back off the lane it will be deleted. Thats is how I want it to be:P
          so is there a script that delete everything that it touch, so would I be pleased to now that. It would be awesome. (I think)
          Thanks,
          Sorry for bad english, its early in the morning here in Sweden right now.
          /hpnisse
            Why not 'hide' them or move them onto an invisible layer ?
            Then you can always 'unhide' or move them back onto a visible layer ??
            • H Offline
              hpnisse
              This should be done in the physics simulation, so if there is to much "pins" in the model at the same time the physics will run slowley.
              And when I hide the pins after they thrown down there will take up a lot of space.
              But I can test with hide the pins and ball when they fall down back of the lane, and see if the physics simulation will run slowley.
              The best thing would be to delete them cause there will be new pins emitted down on to the lane when a new "Round" will start.
              But if there is a script that delete everything that it touch, would I be pleased to know that.
              thanks TIG for the hide tip, I would try that.
              /hpnisse
              • H Offline
                hpnisse
                The hide idea would not work that well, so a script to delete objects when ontouch will probably work better:P (I hope)
                But thanks for the idea.
                /hpnisse
                  /hpnisse
                  If the objects are groups moving them to an invisible layer would both hide them and remove them from interactions ?
                  • W Offline
                    Wacov
                    Hiding an object in SP doesn't affect the simulation, as far as the Physics engine is concerned the object is still present and movable, you just can't see it. Deleting a group is simple, you just get the group handler and use '.erase!', but I don't know how this would affect the sim 😐
                    • H Offline
                      hpnisse
                      What is the "Group handler"? Im searching for help in
                      http://code.google.com/intl/sv-SE/apis/sketchup/docs/ourdoc/group.html
                      but I can't find anything that I understand.
                      So a little more precise instruction would be great!
                      The idea is to delete groups/components when they touched another group.
                      /hpnisse
                      • W Offline
                        Wacov
                        The group's script 'object'. E.g. you've probably come across $curEvalGroup before, that is actual a variable, set to the current group's script object. It's just 'Group' on the API.
                        • H Offline
                          hpnisse
                          Hello again!
                          I have seen the "$curEvalGroup" before, but I did't understand everything. I have test everything I come up with.
                          Can Wacov (or someone else) explain the "group handler", it sounds so simple when you say it.
                          /Wacov
                          And when I test a few examples and combinations with ".erase!" the simulation will freeze, the only that works is to stop the simulation.
                          So a little more careful explanation would be helpful.
                          /hpnisse
                            MrDailyBlah
                            u should only ever delete objects created in simulation, eg emitted objects
