    Switch direction of edge?
    7 Posts 5 Posters 572 Views 5 Watching
      cjthompson
      Is there any way to switch the start and end of an edge? I noticed that many times, loops don't go start to end/start of next line(see examples):
      What I expected.
      What the edge directions actually are.
      It also seems to mess up with Loop.convex?().
        I suggest you look into Weld.rb and several other tools that use similar code to order the vertices in a loop - it's a bit convoluted but 'order_points' is a vital part many scripts...
          Copy 180° rotate it then kill the original?
          • Chris FullmerC Offline
            Yeah, its not possible through the API. Instead you have to figure out the order on your own and track them in a an array or set or hash or something.
            All my Plugins I've written
              As Chris, I write my own routines into the script to sort the edges/vertices..
              Edge.reversed_in? is useful, as well is the EdgeUse class.
                IF the edges are coplanar and they either bound a face or can be given a face, then you can get the face.vertices and these always return ordered and in the same direct relative to the face.normal - counterclockwise if my memory serves we well...
                You can then use these vertices to get an array of ordered points to redo a set of edges so they are all the same direction... I've been thinking of a quick fix where you clone the face.edges into a group from this etc...
                You need to delete the old edges and remake the face etc
                It could be a quick way to make curves too...
                For 3D edge collections it's a slog through the edges and sorting them as Chris says - I believe that it was RickW who was the first to come up with a method for this - as seen in weld.rb ...
                  cjthompson
                  TIG's method of getting the vertices of a face worked for me.
                  Thanks everyone for the replies.
