    How can i create my own Toolbar ... ?
    6 Posts 2 Posters 1.3k Views 2 Watching
    • H Offline
      haynesc
      I have no experence with ruby language ...
      i would like to create my own toolbar for single icon toolbars such as ...
      Zorro, Loft, LaunchIt, Hoverselect and Shape Bender ...
      How would i be able to do this ? ... Also if possible could i merge Subdivide and Smooth and SoapSkin Bubble into one toolbar for example?
      Thanks in advance
      Chris
        Something like...
        require 'sketchup.rb'
        require 'tool1.rb'
        require 'tool2.rb'
        ### etc etc - first you must 'require' each script you want to use...
        def makemynewtoolbar()
          tb=UI;;Toolbar.new(db"MyNewToolbarName")
          tb.restore if tb.get_last_state==TB_VISIBLE
          ### now add each tool in turn to 'tb' ...
          textstring="Tool1sName"
          instructions="Tool1sBriefInstructions..."
          cmd1=UI;;Command.new(textstring){tool1Command()}### as made in original script
          cmd1.status_bar_text=textstring+"; "+instructions
          cmd1.tooltip=textstring
          cmd1.small_icon="my_icons/tool1_16x16.png"
          cmd1.large_icon="my_icons/tool1_24x24.png"
          tb.add_item(cmd1)
          ### then do the same for tool2/cmd2 etc etc ...
        end#def
        makemynewtoolbar() ### finally to make your new toolbar on startup...
        The text 'tool1.rb' etc would actually be replaced by the real file name and 'tool1Command' is the actual code to run the tool that you usually find near the end of each script etc...
        I suggest that you put all of your icons [copied from the original tool's if they exist, or made by you to the sizes shown (16px sq & 24px sq)] in one folder you put inside ../Plugins/ called something like 'my_icons'...
        Hope this helps πŸ€“
        • H Offline
          haynesc
          see when i look at that all i see is a bunch of characters letters and numbers πŸ˜•
          I would like to try this out ... so if i copy that into wordpad and save it as a .rb i have a template right?
          Im still a bit confused into what i need to replace with what ...
          Say I call the Toolbar, "FreeFormModelling" and i want subdivideandsmooth, soapskinbubble, ffd, & extrudetools by YOURSELF ... etc in one long toolbar ...
          require 'SubdivideandSmooth.rb'
          require 'SoapSkinBubble.rb'
          require 'extrudeEdgesbyEdges.rb'
          require 'extrudeEdgesbyFace.rb'
          require 'extrudeEdgesbyRails.rb'
          require 'extrudeEdgesbyVector.rb'
          ###(and so on untill i have all the correct .rb files that i require )
          def FreeFormModelling()
            tb=UI;;Toolbar.new(db"FreeFormModelling")
            tb.add_item(cmd1)
          end#def
          FreeFormModelling() ### finally to make your new toolbar on startup...
          I dont understand that middle peice ...
            I've taken the liberty of editing your code so it's more readable...
            First is Wordpad going to save these as 'plain text' like Notepad ?
            There can't be any 'formating' or it won't load...
            If it'll be plain-text make the file called 'FreeFormModelling.rb' in the Plugins folder.
            Your code:
            The 'require' parts are OK.
            Now you see where it says
            %(#808040)[### now add each tool in turn to 'tb' ...
            cmd1=UI::Command.new(textstring){tool1Command()}### as made in original script
            cmd1.status_bar_text=textstring+": "+instructions
            tb.add_item(cmd1)]
            for each of the tools you 'required' you need to have a 'paragraph' of code, defining its name, instructions, command and icons - then in turn you add the command to the toolbar ('tb')
            You can force the order of the buttons by the order you add the commands...
            To complicate things the first one you list to be added is subdivideandsmooth which is a group of tools and is encrypted so you can't access its commands etc... you also can't make 'pop-out' toolbars so I think you should stick to unencrypted single command tools...
            So let's take the first button as one of my 'accessible' tools - 'ExtrudeEdgesByLoft.rb' - read the script to see what it does in terms of menus, naming itself and toolbars, icons etc - this is [usually] near the end of the code...
            So the 'paragraph' of your code needs the relevant bits adding in...
            textstring=" Extrude Edges by Loft"
            instructions=" : Select Curves: Follow Prompts: to Loft a Mesh..."
            cmd1=UI::Command.new(textstring){ extrudeEdgesByLoft()}### as made in original script
            cmd1.small_icon="my_icons/ extrudeEdgesByLoft16x16.png"
            cmd1.large_icon="my_icons/ extrudeEdgesByLoft24x24.png"
            tb.add_item(cmd1)
            If you were to refer back to the original icons you could use "TIGtools/extrudeEdgesByLoft16x16.png" etc instead.
            Now the next button... let's do 'ExtrudeEdgesByRails.rb'...
            your next 'paragraph' is
            textstring=" Extrude Edges by Rails"
            instructions=" : Pick Curves: Profile, Rail-1, Rail-2 & Melding-Profile. Makes Mesh. Follow Prompts..."
            cmd2=UI::Command.new(textstring){ extrudeEdgesByRails()}### as made in original script
            cmd2.status_bar_text=textstring+": "+instructions
            cmd2.tooltip=textstring
            cmd2.small_icon="my_icons/ extrudeEdgesByRails16x16.png"
            cmd2.large_icon="my_icons/ extrudeEdgesByRails24x24.png"
            tb.add_item(cmd2)
            Note how we increment the command to cmd2...
            Add more commands as desired...
            If a tool only appears in the Menu and has no toolbar you can still make a toolbar button for it using the same idea - just invent the textstring/instructions and make your own icons, and use cmdX=UI::Command.new(textstring){**theCommand()**} where [ruby:2rrnsyr3]theCommand[/ruby:2rrnsyr3] is a copy of the command string inside the [ruby:2rrnsyr3]{ }[/ruby:2rrnsyr3] of the menu's code
            Unfortunately if a command is encrypted you won't know what/how to call it into the toolbar ? 😞
            To see the new toolbar you need to activate it from View > Toolbars...
            Hope this helps though... πŸ€“
            • H Offline
              haynesc
              Your code:
              tb.add_item(cmd1)]
              tb.add_item(cmd1)
              tb.add_item(cmd2)
              If a tool only appears in the Menu and has no toolbar you can still make a toolbar button for it using the same idea - just invent the textstring/instructions and make your own icons, and use cmdX=UI::Command.new(textstring){**theCommand()**} where [ruby:rtq2vrvx]theCommand[/ruby:rtq2vrvx] is a copy of the command string inside the [ruby:rtq2vrvx]{ }[/ruby:rtq2vrvx] of the menu's code
              Thanks for the very detailed and indepth tutorial, when i have time ill have a crack at it ... Cheers TIG btw i love your tools
              • H Offline
                haynesc
                this is way above my concentration levels lol ... i just dont understand the language ... thanks anyway
