    Ruby Script question re soften certain lines only
    6 Posts 2 Posters 1.0k Views 2 Watching
    • P Offline
      pmolsen
      How hard would it be to write a Ruby Script that made all vertical lines in a model soft and smooth please?
        Easy.
        model = Sketchup.active_model
        model.entities.each { |e|
        	if e.is_a?(Sketchup;;Edge) && e.line[1].parallel?(Z_AXIS)
        		e.soft = true
        		e.smooth = true
        model.definitions.each { |d|
        		e.soft = true
        		e.smooth = true
        (Sorry - don't have time to wrap it up in menu system atm)
        • P Offline
          pmolsen
          Hey, thanks a lot for that quick response.
          Actually what I should really have asked is how do I select all vertical lines. Then I can do whatever I want with them.
          • P Offline
            pmolsen
            Tried to finish it off but getting syntax error on the last line. Never created one before. Any ideas please? File is called softenv.rb and is in the plugins folder:
            Soften all vertical lines in a model
            require 'sketchup.rb'
            def soften_vert
            if e.is_a?(Sketchup::Edge) && e.line[1].parallel?(Z_AXIS)
            e.soft = true
            e.smooth = true
            e.soft = true
            e.smooth = true
            if( not file_loaded?("softenv.rb") )
            add_separator_to_menu("Plugins")
            UI.menu("Plugins").add_item("Soften vertical lines") { soften_vert }
            file_loaded("softenv.rb")
            • P Offline
              pmolsen
              Ok, I think I was missing an "end" on the last if statement. Fixed that and now get no syntax errors but the option does not appear on the Plugins menu when I restart SU...
              • P Offline
                pmolsen
                Shuffled things around a bit by copying other scripts and got the menu item to appear. Not sure how. But when I select the option nothing happens:
                def abc
                e.soft = true
                e.smooth = true
                e.soft = true
                e.smooth = true
                name = "softenv.rb"
                unless file_loaded?(name)
                UI.menu("Plugins").add_item("Soften verticals") { abc }
                file_loaded name
