Ruby Script question re soften certain lines only
6 Posts 2 Posters 868 Views 2 Watching
    pmolsen
    How hard would it be to write a Ruby Script that made all vertical lines in a model soft and smooth please?
      Easy.
      model = Sketchup.active_model
      model.entities.each { |e|
      	if e.is_a?(Sketchup;;Edge) && e.line[1].parallel?(Z_AXIS)
      		e.soft = true
      		e.smooth = true
      model.definitions.each { |d|
      		e.soft = true
      		e.smooth = true
      (Sorry - don't have time to wrap it up in menu system atm)
        pmolsen
        Hey, thanks a lot for that quick response.
        Actually what I should really have asked is how do I select all vertical lines. Then I can do whatever I want with them.
          pmolsen
          Tried to finish it off but getting syntax error on the last line. Never created one before. Any ideas please? File is called softenv.rb and is in the plugins folder:
          Soften all vertical lines in a model
          require 'sketchup.rb'
          def soften_vert
          if e.is_a?(Sketchup::Edge) && e.line[1].parallel?(Z_AXIS)
          e.soft = true
          e.smooth = true
          e.soft = true
          e.smooth = true
          if( not file_loaded?("softenv.rb") )
          add_separator_to_menu("Plugins")
          UI.menu("Plugins").add_item("Soften vertical lines") { soften_vert }
          file_loaded("softenv.rb")
            pmolsen
            Ok, I think I was missing an "end" on the last if statement. Fixed that and now get no syntax errors but the option does not appear on the Plugins menu when I restart SU...
              pmolsen
              Shuffled things around a bit by copying other scripts and got the menu item to appear. Not sure how. But when I select the option nothing happens:
              def abc
              e.soft = true
              e.smooth = true
              e.soft = true
              e.smooth = true
              name = "softenv.rb"
              unless file_loaded?(name)
              UI.menu("Plugins").add_item("Soften verticals") { abc }
              file_loaded name
