    Problems in face selection on Dell Optiplex 755 machine
    4 Posts 3 Posters 688 Views 3 Watching
      arjunmax09
      I have this dell computer in my college lab. on workin' with sketchup on it... sketchup doesn't recognise faces as expected .... i've installed its graphic drivers... but the problem persists... I'm using sketchup pro 7.1 on it....I've attached a video of this problem... I've used thomthom selection toys so that it shows that which faces are highlighted when i hover my cursor on one.....Every dell model in this lab that is the optiplex one has this problem....
      But this happens while editing a group only... loose geometry behaves fine...
      Problem in face selection on dell machine.rar
      when you fail at something....you haven't really failed...you've found one way the thing will not work out
      • sketch3d.deS Offline
        sketch3d.de
        try if disabling "Window > Configuration/Settings (?) > OpenGL > Fast Feedback" and/or "Hardware Accelertation" helps.
        if yes, the OpenGL support of the video subsystem (which?) resp. the used video driver (which?) is lame.
        hth,
        Norbert
        • AnssiA Offline
          Anssi
          According to Dell brochures, this model comes with either an Intel GMA on-board graphics chip, or one of three models of lower-end ATI Radeon graphics cards. The Intel graphics don't support OpenGL hardware acceleration, and the problems you describe point to this direction. If the graphics card is an ATI one, you may be in more luck, but you would have to look for a suitable driver, possibly from the ATI pages. ATI cards have had their problems with SU, but I understand many users have been able to use them OK with SU.
          Anssi
            sketch3d.de
            if ATI isn't able to provide a working driver, the quality-moded OmegaDrvier is always worth a try.
            Norb.
