    Vertically Smooving a surface
    4 Posts 2 Posters 427 Views 2 Watching
    • A
      arjunmax09
      i was just wondering.... is there a way to rotate the smoove circle of the sandbox tool... so that we don't have to rotate the contoured surface... was making falling water....
      when you fail at something....you haven't really failed...you've found one way the thing will not work out
      • thomthomT
        No. Rotate the surface first - then smoove and rotate back.
        I am working on a Vertex Edit plugin - but it's still got quite a bit of work to be done.
        • A
          arjunmax09
          so what is the vertex edit plugin all about???
          • thomthomT
            Other modelling packages often let you edit the geometry by editing the vertices.
            http://forums.sketchucation.com/viewtopic.php?f=180&t=18021&p=227736#p227736
            With this Vertex Editing plugin I'm making, you will be able to use soft selections - so that when you do changes, like move a set of vertices, the ones at the edge of the selection is affected less.
            http://forums.sketchucation.com/viewtopic.php?f=180&t=26387&p=227665#p227822
