    [Req] Check for N-Gons
    25 Posts 6 Posters 4.0k Views 6 Watching
      Khai
      actually to divide them into Quads (preferred) or Tris - I use Sketchup as a modeler for other programs you see, they prefer no N-Gons... (Mainly poser content)
        remus
        TIG, i realise the current script only works in the current context (in a group etc.), it was on purpose as i thought it was more useful than only being able to check the faces in the highest context.
        On another note, does entities not include faces, edges etc. that are within components? If so that would explain why khai was having trouble with it...
          active_entities is everything in the current edit session - i.e. in the model or a group or component being edited.
          entities is everything in the model - as in model.entities but stops short of nested stuff so it lists all geometry, groups, instances etc.
          You also use entities for other containers like groups or component_definitions - e.g. group.entities and definition.entities. again these stop short of listing nested stuff.
          To find ALL entities you need to do my trick of iterating through the model.definitions and going through the entities of each definition...
          Remember too that if you are changing entities always use an array as in ents.to_a - changing entities as you ' each' loop through them leads to unpredictable results as the entities list constantly changes and so it becomes confused...
            remus
            Cheers for the explanation πŸ‘
              Khai
              presto reserectus!
              http://forums.sketchucation.com/viewtopic.php?f=169&t=24681&p=247955#p247955
              I'm wondering if this can be expanded now to highlight the Ngons? we're finding with Sculptis it rejects any faces with more than 4 faces....
                remus
                Try this in the webconsole. To be honest your probably better off using TIGs triangulate faces ruby, though...
                model = Sketchup.active_model
                entities = model.active_entities
                selection = model.selection
                n = 0
                entities.each{|e|
                  if e.is_a? Sketchup;;Face
                    if e.edges.length > 4
                      n += 1
                      selection.add(e)
                if n > 0
                  UI.messagebox("Contains N-Gons (Faces with >4 sides)")
                else
                  UI.messagebox("N-gon free!")
                  Khai
                  webconsole?
                  and I explained back in this thread.. I can't tri the mesh. I'm moving from here (I love the modeler!) to app that don't like things being totally tri's... so that ruby's no good to me.
                    remus
                    Webconsole is a handy little ruby that lets you run bits of ruby in SU without having to package it as a separate file. You can find it here: http://sketchuptips.blogspot.com/2007/08/plugin-webconsolerb.html
                    Just install it as usual, open SU, hit the appropriate menu item, copy and paste the code in and click run.
                    I'll get going on a normal version, but no promises. Its been a while since ive written a ruby.
                      remus
                      Ok, here you go.
                      Several improvements in v.3:
                      works over the entire model (in groups and components), thanks to TIGs handy little snippet.
                      Adds all N-gons to a new selection
                      Tells you how many N-Gons there are in the model
                      Added a Tri check which can be accessed by typing tri_check() in to the ruby console
                      ngon_check.rb
                      • StinkieS Offline
                        Stinkie
                          Khai
                          not working right.... it's reporting everything has 18 N-gons... even a cube.....
                          wish I could help 😞 but I'm no programmer 😞
                            remus
                            Hmmm, most unusual. Working ok for me. Could you post a problem model?
                              Khai
                              no point.. since even a simple six sided cube is reporting '18 Ngons' tho, if I add 3 Ngons... it reports '21 Ngons' !
                              for some reason it's reporting 18 instead of 0....
                              Edit
                              Found the problem. it's checking all the entities in the scene. example : a new scene automatically has 18 Ngons = the default human figure.
                              even deleting him, he registers in the Ngon check.. do a purge and remove him totally, it reports correctly...
                              • 2 / 2
