    FredoScale for Mac
    9 Posts 6 Posters 2.2k Views 6 Watching
      Ricardo Parisi
      Saluti...
      I've just tried to wade through the 27 page FredoScale post and it's quite daunting (for me at least) to figure out what I need to do to install this amazing Plugin on my Mac.
      Is there someplace where I can find the latest downloads and directions regarding the installation.
      I'm using SU 7 and have several plugins already installed so I do know where they go and stuff like that.
      Thanks.
        d12dozr
        The plugin is at the bottom of the first FredoScale post, you'll also need LibFredo...link to that should in the first FredoScale post too.
        http://goo.gl/f7ooYh
          Ricardo Parisi
          Sorry, but I am a at a loss on this one. There are so many changes to files and Mac bug fixes I'm swimming.
          So far I have downloaded 'Lib Fredo6 3.4' and 'FredoScale 2.Oh' - unzipped and added the 'Lib' file to the SU7 Plugins THEN dropped the 'FScale' folder into that file.
          All I get is an 'error load' message.
          I've loaded a ton of other plugins without a prob... not sure why I'm losing this battle.
          Dazed and confused.
          • jeff hammondJ Offline
            jeff hammond
            here are the direct links: (the first one is the current fredoscale, the second is for libfredo)
            http://forums.sketchucation.com/download/file.php?id=35247
            http://forums.sketchucation.com/download/file.php?id=34712
            -- unzip the files (unless you have safari set to do that automatically after downloading)
            -- open the folder titled "FredoScale%202"... inside you will see two items -- a folder named FREDOSCALE_Dir_20 and a file named ZLoader__FredoScale.rb
            -- place those two items inside the plugins folder at:
            Macintosh HD / Library / Application Support / Google SketchUp 7 / SketchUp / plugins
            -- open the folder titled "LibFredo6%203"... inside you will see two items -- a folder named LIBFREDO6_Dir_34 and a file named LibFredo6.rb
            -- place those two items inside the plugins folder mentioned above.
            -- launch sketchup
            dotdotdot
            • Mike LuceyM Offline
              Mike Lucey
              Thanks Jeff, that was very helpful.
              Mike
                Ricardo Parisi
                Perfect...thanks Jeff.
                Everything works great, however, I also get an error message on startup: Error loading file BzRoundEdge.rb/No Such file LibTraductor.rb
                cheers,
                  chrisjk
                  LibTraductor.rb should be located in Macintosh HD / Library / Application Support / Google SketchUp 7 / SketchUp / plugins
                  Evidently from the error message, it's not there. I have attached a copy to this message which you can download.
                  LibTraductor.rb
                  Chris
                    Ricardo Parisi
                    Easy peasy - done like dinner - thanks Chris.
                      Skateparks
                      Same problems, no solution despite trying everything. I'm going to uninstall and reinstall everything?
                      Also, my Preferences > Extensions folder does not contain anything useful either.
                      HELP!!
