    Text to component
    7 Posts 2 Posters 1.3k Views 2 Watching
    • mariochaM Offline
      mariocha
      Hi all,
      Is there a .rb that can substitute a component for a text?
      I mean can a text, let's say "A", be replaced by a component named "A".
      That would be helpfull for me.
      Or even better a selection of several texts replaced by the name-equivalent components.
      %(#008000)[Mario C.
        def text2compo()### replace text with a compo
              model=Sketchup.active_model
              ss=model.selection.to_a
              defs=model.definitions
              ss.each{|e|
                if e.class==Sketchup;;Text
                  txt=e.text
                  pt=e.point
                  next if not pt
                  ### text must have a location == i.e. have a leader
                  defn=defs[txt]
                  ### text must match compo name exactly including Case
                  if defn
                    tr=Geom;;Transformation.new(pt)
                    model.active_entities.add_instance(defn,tr)
                    e.erase!
                  end#if
                end#if
        end#if
        def compo2text()### replace a compo with text
              ss.each{|e|
                if e.class==Sketchup;;ComponentInstance
                  txt=e.definition.name
                  ### text will == compo defn's name
                  pt=e.transformation.origin
                  model.active_entities.add_text(txt,pt,[10,10,10])
                  e.erase!
                end#if
        end#if
        copy/paste into a file in Plugins folder called text2compo.rb, to use select the text and type text2compo in the Ruby Console, and if there's a component with that exact same name loaded into the Model then it's replaced...
        To replace selected components with text use compo2text...
        πŸ€“
        • mariochaM Offline
          mariocha
          Hey, Thanks for the quick answer TIG.
          You really know your stuff.
          One small bug thought.
          Upon SU launch
          *%(#0000BF)[Error Loading File text2compo.rb
          /Users/xxxxxx/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/text2compo.rb:13: parse error, unexpected kIF, expecting ']'
          if defn
          and Ruby console
          %(#0000BF)[> text2compo
          Error: #<NameError: undefined local variable or method `text2compo' for #Object:0x378f9e4>
          (eval):1034
          I did make sure I had everything copied, twice. πŸ˜›
          %(#008000)[Mario C.
            There was a typo in the original code - I quickly fixed it and it should now be working.
            I suspect you managed to copy it before I corrected it !
            Try recopying the code and try again - it works for me.
            You must match the text and the defn name exactly...
            πŸ€“
            • mariochaM Offline
              mariocha
              Yes Sir, works pretty well now.
              Thanks a lot.
              impressive, what the combination of Ruby with an expert can do, and quickly.
              %(#008000)[Mario C.
              • mariochaM Offline
                mariocha
                Ah... one more thing, if I may.
                Could the script be activated with right-click ?
                updt: I managed to get it in the Tools menu. πŸ˜„
                updt: and the contextual also.
                I'm learning a bit of Ruby just by looking at .rb files πŸ˜›
                %(#008000)[Mario C.
                • mariochaM Offline
                  mariocha
                  I gave another shot at the file and succeeded in making it work on any text string of 1, 2 or 3 characters. πŸ˜„
                  %(#008000)[Mario C.
